Previous in Forum: Steam Turbine Power Output vs. Condenser Vaccum   Next in Forum: Grease Interceptor, Commercial
8 comments
Check Valve
09/27/2012 6:08 AM
Hi Dear All
I need your kind help concerning choosing check valve using on roof rain harvesting system. Additional information for this, we will use this equipment under ground as verticalar without any maintenance chamber.
Thank you in advance.
Good Answers: 34
Re: check valve
09/27/2012 6:29 AM
Where is the need of a check valve in a line of gravity dependent free flow, harvested from roof?
Re: Check Valve
09/27/2012 11:35 AM
If you have more than one branch running off the downcomer, you need a ball, gate, butterfly type valve, not a check valve.
There are also in-line flow restrictors that are not adjustable.
Beyond that, I have no idea what you really are trying to do.
If this isn't homework, why not telk to your valve supplier. They will want to help you, since they will sell you the valves.
Re: Check Valve
09/27/2012 11:59 AM
Is there no choice other than to install this questionably required valve "...under ground as verticalar without any maintenance chamber."? This seems short sighted as well as a road to problems in the future.
Re: Check Valve
09/28/2012 12:10 AM
எதுக்காக? What for? A check valve prevents back flow.
Rain water flows through the down spout into the sump or the ground water recharging pit. Are you having a different application?
bioramani
Good Answers: 34
Re: Check Valve
09/28/2012 12:40 AM
In this case, it is supposed to prevent back flow to where?
Engineering Fields - Civil Engineering - Member Engineering Fields - Construction Engineering - Member Engineering Fields - Mining Engineering - Member United States - Member - Member Popular Science - Weaponology - Member Hobbies - Target Shooting - Member Hobbies - Car Customizing - Member
Re: Check Valve
09/28/2012 7:52 AM
Most check valves for water have an exterior spring and arm. If you direct bury this check valve, I do not see how it will operate properly. Also, this seems unneeded. If you are concerned about connectivity to the potable system, a PRZ would work better.
You cannot escape the responsibility of tomorrow by evading it today - Abraham Lincoln
Good Answers: 179
Re: Check Valve
09/28/2012 9:08 AM
I see no need to install a check valve on a gravity fed system.
If you do anything, make sure you install a mossie-proof net on top of your rain collection barrel, lest it become a Mosquito breeding ground! You don't want to get bitten and come down w/ Malaria or West Nile Virus....
Good Answers: 102
Re: Check Valve
09/29/2012 12:00 AM
ckaraman34
Mate, do you reckon you could provide a sketch of your proposed arrangement?
No maintenance chamber now will have you building one later on....unless this is a short term solution to a temporary need and will be abandoned post immediate benefit.
Register to Reply 8 comments
bioramani (1); CaptMoosie (1); Doorman (1); Joshi (2); lyn (1); Old Coal Man (1); Wal (1)
