Previous in Forum: Porosity Specification For Aluminium Die Castings   Next in Forum: Looking for a Manufacturing Partner
9 comments
Material Used for Manufacturing of Blades
09/27/2012 11:57 AM
what to use and from where to purchase the material used for manufacturing of blades used to cut scrap rubber tyre pieces ?
Re: jo
09/27/2012 12:21 PM
These should do the job.
"It's not the dress that makes you look fat. It's the fat that makes you look fat." - Al Bundy
Good Answers: 34
Re: Material Used for Manufacturing of Blades
09/27/2012 12:59 PM
Select a suitable blade HERE
09/27/2012 1:06 PM
I think OP wants to make his own blades.
Hard to tell from the post.
Good Answers: 34
09/27/2012 1:16 PM
Most likely, the OP wants to pick-up some suitable steel, from scrap yard & make some knives, for his intended purpose.
09/27/2012 1:03 PM
There are thousands of metal suppliers, all over the world.
Since we have no idea where you are, maybe you should contact a local supplier of metals.
  1. Online Metal Store | Small Quantity Metal Orders | Metal Cutting ...
  2. METAL SUPERMARKETS - Buy Metal Online - Small Quantity ...
  3. Or go here and search:Search GlobalSpec for metal suppliers
09/27/2012 3:42 PM
The easiest way is to just buy a tyre shredder.
For example
Link
09/30/2012 5:47 PM
Cr6 are used to cut the rubber but you have to calculate the blade thickness as per your rubber thickness ,many chinese companies can make it as per your design and specs.regards
love4everyone
Good Answers: 123
10/01/2012 10:18 PM
The blades will need to be heavy, or attached to a heavy arbor. The blades will need to be carbide or similar materials. The steel cords in tires is tough, and will dull standard steel blades in short time.
Bob
05/18/2013 5:28 AM
Many years ago I worked as an apprentice for an engineering company in West Yorshire UK. The Managing Director pioneered a manually operated system to remove and recoup rubber from old tires using a high velosity spiky wheel with pins inset. It recovered 95% of the rubber from a standard car tire in less than 5 minutes without any noticeable charring or smell.
Register to Reply 9 comments
bob c (1); jack of all trades (1); Joshi (2); lyn (2); pristex (1); sohail0110 (1); thall (1)
