Previous in Forum: notes   Next in Forum: Mechanized system
9 comments
Welding symbol
05/18/2007 2:41 PM
Good morning
I'm european designer and I have no idea what does it mean this "M" at drawing. Does somebody can help me?
For every help thanks a lot.
Pathfinder Tags: symbol Welding
Re: Welding symbol
05/18/2007 3:28 PM
It means that the weld surface is to be machined flush.
Re: Welding symbol
05/18/2007 10:10 PM
There should be a standard symbols drawing somewhere as well, to enable the codes on any other drawing to be read. Otherwise, how does the drafter know what to put on the drawing in the first place (rhetorical question)?
Check for a drafting standards manual.
Also, the initials of the drafter, the checker and the approver will appear on the drawing somewhere; these are some people to ask.
Re: Welding symbol
05/18/2007 10:26 PM
Exactly. The purpose of a drawing is to communicate. How can one do that without the 'dictionary'?
United States - Member - New Member Popular Science - Weaponology - New Member
Re: Welding symbol
05/19/2007 12:23 AM
"Also, the initials of the drafter, the checker and the approver will appear on the drawing somewhere; these are some people to ask."
Only in your dreams. If you do find them good luck making contact, and if you do make contact you will be very fortunate indeed if they understand the symbols themselves.
Sorry, I have seen way too many bad drawings. Maybe I should start a forum on what not to do on a drawing.
There are plenty of books and references on GDT (geometric dimensioning and tolerencing) and ANSI standards with explantions of drafting symbols. Machinery's Handbook also has this info.
Men are like steel, if they lose their temper they are worthless.
Engineering Fields - Manufacturing Engineering - United Kingdom - Member - Get things done!
Re: Welding symbol
05/21/2007 6:23 AM
'Sorry, I have seen way too many bad drawings. Maybe I should start a forum on what not to do on a drawing.'
I'll go with that. My experience is that since we have thrown away our drawing boards (metaphorically I hope!) and anyone and his dog can get a drawing package on the old PC causing standards to fall like a rock.
'The truth is out there' The lies are in your head.
Re: Welding symbol
05/18/2007 10:56 PM
Symbol without M means flushing off the weld by any means grinding or machining and with M means weld to be machined flush
Re: Welding symbol
05/18/2007 11:05 PM
If the symbol is without M then it means weld to ground or machine flush. Symbol with M means weld to be machined flush.
Re: Welding symbol
05/19/2007 6:16 AM
According to ANSI/AWS A2.4-98, [Para. 13.3.2 Finishing Methods], the following finishing symbols may be used to specify the method of finishing, but not the degree of finish:
C - Chipping, G - Grinding, H - Hammering, M - Machining & R - Rolling
Re: Welding symbol
05/19/2007 9:29 AM
From now I understand this symbol. Thanks for every post.
Abdel Halim Galala (1); Anonymous Poster (5); garyceng (1); Harbir Singh (1); PlbMak (1)
