Previous in Forum: Water Cooling - Other Applications?   Next in Forum: Audio Door Phone Connection Diagram
19 comments
Can Someone Identify This Battery From a Bleeper II Please?
09/28/2012 3:24 PM
Could anyone help? I want to know what this battery is called and its voltage?
What is a Bleeper II?
09/28/2012 4:01 PM
Internet search for a 'Bleeper II' gets one hit: this thread.
At some risk that this may be a henway or duckdo... What's a Bleeper II?
Re: What is a Bleeper II?
09/29/2012 8:25 AM
When I put batteries in my henway it changes it's physical attributes a bit. My duckdo uses type BS batteries.
Re: Can Someone Identify This Battery From a Bleeper II Please?
09/28/2012 4:05 PM
Inches, meters, feet, what's the unit of measure and you really need the diameter, height and voltage is probably 9..
Really, any 9 volt battery will do. The bleepers run on 9-12 V. Just put a
  • in its place.
Good Answers: 69
09/28/2012 4:11 PM
I found a lot of similar batteries, measure it more accurately and specify voltage also.
The closest match was: SANYO CR-1/3N Diameter 11.6mm Height 10.8mm 3 volts.
You can Google it yourself.
Good Answers: 104
09/28/2012 4:15 PM
Fluke has a Bleeper III that uses 2 AAA alkaline batteries. But unless your picture is distorted, those aren't them. What brand is a Bleeper II?
09/28/2012 4:30 PM
The bleeper II is a metal pen style Geiger counter with a pocket clip on one end. It takes two of these batteries and the ruler in the picture is in millimeters. I should have clarified its a Geiger counter because there are a number of devices that exist called bleeper. I could just connect a power supply to its terminals and increase the voltage until it comes to life but on the other hand I don't know if it works and it might be nice to try getting some batteries for it. Thanks for peoples interest and replies.
09/28/2012 4:34 PM
Measure it with a voltmeter....oops, your voltmeter's batteries are missing.
09/28/2012 4:41 PM
My fluke say about 10mV and I think that means they are completely flat and its 16mm in diameter and about 16mm in length.
09/28/2012 4:49 PM
Made by by Pendix (I think thats what it says)
09/28/2012 5:31 PM
These LOOK like they may be camera batteries. My Minolta took two cells but the camera store sold a single battery that was the same as two regular batteries but in a single case. Looked like these, as I recall.
Your set-up maybe could use 4 regular button batteries stacked, if the voltage works out right.
Disregard my 9V battery suggestion, but most beepers of that sort are 9-12V.
09/28/2012 6:34 PM
Good Answers: 145
09/28/2012 6:46 PM
Yup they be CR1/3 3Volt 200mAh batteries Yahlasit nailed it.(GA)
Yes they're a "Photo" battery a bit hard to come by but you can get the lithium ones online readily enough.
I've been looking at Lithium batteries for a work project, and while the size is great there's not enough grunt(for this particular job) could only find one in a chemist(drugstore?)and I went to several in a 30km radius. Google for the Varta, Lisun, Duracell websites they have battery comparisons and data sheets.
09/28/2012 7:02 PM
09/28/2012 7:26 PM
I was looking at the varta data-sheet for the CR1/3 and its diameter is 11.4mm and height 10.4mm. My battery is about 16mm diameter and about 16mm high. Very much doubt its for detecting electromagnetic radiation because it uses a metal case and has no antenna under plastic cap or anywhere.
09/28/2012 10:24 PM
Update on this. I connected a power supply to this and it came to life when about 3 volts is provided. That means each battery is around 1.5 volts (though I still dont know type number of battery). And it does measure radiation. My lump of pitchblende which is about 30 microsieverts/hour in activity makes device beep once every ten seconds when placed right up against it. I cant get a clear view of circuit inside but its using things like silicone transistors and I would guess it dates from maybe 1980. Very interesting object. I welcome any info about it at all and thanks for all comments to date. Now I know how many volts it wants I am sure I will find some battery to fit. david in uk.
09/29/2012 12:33 PM
This might work....$5
The CR123A is a 3-Volt Lithium primary battery (non-rechargeable) - SANYO brand. Size: 33.8mm long x 16mm diameter (1.5" x 0.67"). Fits in cameras, mini flashlights, memory, etc. Premium-quality
09/29/2012 6:09 PM
Thanks for this idea. I just bought a couple of these and will cross my fingers they fit.
09/29/2012 12:55 PM
Very similar to early hearing aid batteries
Tony Aston
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
09/29/2012 1:17 PM
Yup, used in camera's from around the 1970's, Minolta used a lot of these. But this is an easy one. Replace with 2 357's or 675's in series. You can buy these at the supermarket or pharmacy for about a buck a piece on a card.
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
Register to Reply 19 comments
bigg (1); Bricktop (1); Doorman (1); lyn (2); SolarEagle (3); Tank Circuit (6); Tobugrynbak (1); Tom_Consulting (1); Tony Aston (1); Tornado (1); Yahlasit (1)
