Previous in Forum: Grigsby-Barton Data Sheet   Next in Forum: Arc Flash Calculation
Transformer Ratio
10/01/2012 9:16 AM
what is the effect of increasing the number of winding by keeping the transformer ratio same (eg. CT ratio 100/1A to 500/5A) ?
Re: Transformer Ratio
10/01/2012 9:37 AM
The CT becomes larger than it was, which may become larger than it needs to be.
Good Answers: 34
10/01/2012 2:43 PM
The turns ratio is based, on the magnetic permeability & the cross-section area of the transformer core.
Good Answers: 104
10/01/2012 8:51 PM
I could be wrong, after all, I'm just a dumb ole ME, but I don't think that going from 100/1 to 500/5 necessarily means that the number of winding turns has increased.
Good Answers: 131
10/03/2012 12:16 PM
This is true! While the transformation ratio of a current transformer is often given as a ratio of XXX/5A, the actual winding ratio will be YYY/1A. This is due to the fact that the primary will be one conductor through the window of the CT, with YYY secondary coils wound around it.
10/01/2012 11:48 PM
cost,size,space required increases and wastage of valuable material.
pnaban
bigg (1); Joshi (1); PeterT (1); pnaban (1); PWSlack (1)
