Previous in Forum: Diameter and Thickness of Pressure Vessel   Next in Forum: Maximum Allowable Deflection Rolls
Method Statement for New Underground Steel Storage Tank Fabrication & Erection
10/03/2012 4:23 AM
I would like to fabricate an underground steel storage tank, can someone get me method statement for this type of exercise
Re: method statement for new underground steel storage tank fabrication & erection
10/03/2012 4:31 AM
Put a big concrete slab under it, and strap the tank down. This will keep it from "floating" to the surface in the event of seismic soil fluidization. Other folks will no doubt provide further suggestions.
10/03/2012 5:06 AM
whether the tank is mounted /buried.?
Whats the design pressure.?
what is the shape of tank?
what is the medium carried by tank.?
If its atmospheric pressure , medium is flammable liquid and combustible liquids and cylinderical shell
then follow UL-58 rules
it gives rules for construction of shell,head,piping,connections,manways,bracing,marking
this code do not cover corrosion protection which may be required by Local,state authorities.
Corrosion protection systems are covered by UL-1746.
If the welded steel tanks are for oil storage then
follow API 650.
Engineering problems are under-defined, there are many solutions, good, bad and indifferent. The art is to arrive at a good solution.
Good Answers: 92
Re: Method Statement for New Underground Steel Storage Tank Fabrication & Erection
10/03/2012 11:28 AM
Both answers above are excellent, but as someone who's dealt with environmental remediation I say the best answer (if it will contain anything that could possibly become a pollutant) is:
  1. Build it aboveground.
  2. Leave it aboveground!
10/04/2012 12:54 AM
Due to some factor and criterias, when it has been decided that its underground, it means it is.
next is how to design it then how to fabricate and then installation comes.
ADIBA NASIR (2); JNB (1); Tornado (1)
