Previous in Forum: Transient Over Voltage   Next in Forum: Capacitor Start & Run
13 comments
Difference Between NGR and NCT
10/05/2012 9:15 AM
hi..., can u explain the difference between NGR & NCT ?
Re: difference
10/05/2012 9:39 AM
Do you know what the letters NGR and NCT stand for?
Since it is in the EE section, may we assume that they are electrical terms?
Re: difference
10/05/2012 9:43 AM
Well they both have the letter "N".
Could you possibly give us a little context about these six letters. We have no idea where these six letters come from because you have not told us where they come from. For all we know your trying to compare the National Comedy Theater and the Next Generation Racing at an electrical engineering forum. Now "NGR" can be a couple of common electrical engineering terms but I am not going to guess what either of these acronyms stand for. You, sharanabasava1, must communicate with us better than you have or accept becoming the brunt of our jokes.
Good Answers: 181
Re: difference
10/05/2012 1:05 PM
In the UK Narrow Gauge Railways are on average 2'¼" and Nottingham City Transport use 4'8½" for their tramways. So the difference would be 2'8¼".
Re: difference
10/05/2012 1:07 PM
Good Answers: 131
Re: Difference Between NGR and NCT
10/05/2012 10:24 AM
If these abbreviations are what I would normally expect to see in relation to each other (Neutral Grounding Resistor and Neutral Current Transformer), the full name gives you the difference. The NGR is a resistor, which is used to limit fault current in the event of a ground fault in a wye electrical system. The NCT is a current transformer used to measure that fault current in the neutral, so that your protective equipment (relays and circuit breakers) can disconnect your faulted equipment from the rest of the system when a ground fault occurs.
Good Answers: 44
10/05/2012 11:26 AM
His drawings just say NGR and NCT...he didn't know what they actually were.
10/05/2012 11:36 AM
What drawings? At the time of this reply the OP has yet to return with any useful information about any of the three threads started by the OP.
Good Answers: 44
10/05/2012 7:21 PM
That was a contrivance on my part...trying to get into the mind of the wiley random post-er.
10/05/2012 11:22 PM
There are 3 kinds of relays for Earth fault,namely restricted,standby and another whose name I can't recollect.
pnaban
10/05/2012 5:02 PM
Good Answers: 170
10/06/2012 11:24 AM
NGR is Neutral Groundig Resistor
NGT is Neutral Grounding Transformer
And... the difference is one is a resistor and the other is a transformer.
10/06/2012 11:29 AM
NGT≠NCT
10/06/2012 11:40 AM
Never Generate Revenue is a sure recipe for bankruptcy. Unlike Now Cash This will allow you to pay the bills but end up with less personal property.
For those who insist on a electrical engineering absurdity...
Network Greatly Reduced versus Network Constant Traffic for proper design to reducing communication collisions.
So where do I send my consultancy bill?
Register to Reply 13 comments
cuba_pete (2); electricalexpert65 (1); lyn (1); nobodysomebody47 (1); PeterT (1); pnaban (1); redfred (5); TonyS (1)
