Previous in Forum: 220kv/33kv Substation   Next in Forum: Starting Current of Chiller Motor
Bus Sequence Interconnect Issue
10/06/2012 8:17 AM
I am having a bus duct with phase sequence as RR , YY and BB configuration. I want to connect this busduct with panel having RYB, RYB configuration. How to connect both these.
Good Answers: 73
Re: BUS SEQUENCE INTERCONNECTION ISSUE
10/06/2012 10:13 AM
Sounds OK to me so far. But then again, you have provided so little information that your guess is as good as mine. How about a picture or a better description? Your answer is only going to be as good as your question. It is your job on the line if you act on information obtained by being less than precise. You need to consider such things as ampacity, circuit breaker size, and electrical code regarding branch circuits. Or better yet, find a qualified electrician in your area and ask him. Your question indicates that you are not qualified to deal with this problem by yourself!
10/06/2012 11:00 AM
Copper wire is the normal means of connecting such items.
Good Answers: 19
Re: Bus Sequence Interconnect Issue
10/06/2012 2:04 PM
Suitable adopter Box has to be made.Kink connections with required clearances to be made to suit the site conditions.One should have all the dimensions of both End chambers of BUSDUCT and switch board in x,y and z axis to arrive at proper design.
In short Engineering has to be done.
Ramesh,Freelance Electrical/automation Consultant
Good Answers: 34
10/07/2012 4:34 AM
I have not gone through the link. See if it's of any help to you:
CHAPTER-V COMMISSIONING TESTS for Tneb Hand Testing Bookwww.scribd.com/doc/.../6/CHAPTER-V-COMMISSIONING-TESTSYou +1'd this publicly. Undo3 Mar 2012 - One person was posted in the B/B relay panel in the control room at yard. .... Set right and synchroscope showed 12 O'clock O.K. R-R, Y-Y, B-B ... It is impossible to interchange two phases to make it RYB upto the output of 230 KV ... Thus, for the same bus duct connections of 11 KV and 230 KV cable ...
Joshi (1); lyn (1); NotUrOrdinaryJoe (1); ramvinod (1)
