Previous in Forum: Hydraulic Grab Hose Drum Follower   Next in Forum: Analyse or Measure Spring Steel Wire Rod Pickling Quality!
JIB Crane Design Calculations
10/08/2012 7:42 PM
i would like 2 kno how to determune the bending sress on the column of the standing jib crane. i already calculated the bending sress on the jib arm due to a load of 4000lbs...i also calculated the compressive or bucling stress on the column..but i was told the column undegoes both bending and comresssive.is the bending cause by the same moment of the arm?? help plez..how do i design the column
Re: jib crane design calculations
10/08/2012 7:47 PM
Will this be used to lift your blind flange?
Good Answers: 21
Re: JIB Crane Design Calculations
10/09/2012 12:07 AM
This may help some, but it is still a ways from where you need to be to understand all of the functions and loads placed on support columns. Euler's formula will give you most of what you seek.
10/10/2012 6:43 PM
consult the manufacturer.
Register to Reply 3 comments
durtieduck (1); fixitorelse (1); lyn (1)
