Previous in Forum: Criteria for shear key design in base plate   Next in Forum: 12 Dots = 5 Lines
Shim Pack Size Used Underneth of Column Base Plate
10/12/2012 12:45 PM
  • what are the Shim pack sizes are used underneth of column base plate
Re: Shim pack size used underneth of column base plate
10/12/2012 12:57 PM
Do your own homework.
Good Answers: 114
10/12/2012 2:26 PM
What do you think would work?
Good Answers: 179
Re: Shim Pack Size Used Underneth of Column Base Plate
10/13/2012 8:57 AM
Seriously, you need to perform a Google search for this item. There are standard sizes for all sorts of applications, mainly based on size of the baseplate.
Are you shimming a steel column baseplate under a leveling plate first, then packing the void with non-shrink non-metallic grout???
10/14/2012 9:41 AM
thank you. but i need generel sizes that means thickness and width of the shim plates
Good Answers: 179
10/14/2012 9:50 AM
Usually the steel fabricator who supplies the column and baseplate makes them in the shop....as steel wedges.
Talk to the steel fabricator. I know of no companies that make these.
Are you a Contractor?
[Hey, look at me, I have my Joltin' Joey Biden rubber mask on! It's close to halloween ya know. Now, watch me roll my eyes!!!!! LOL]
10/23/2012 7:18 PM
shim packs are used to to elevate the columns to the correct elevation and to provide enough space to grout between base plate and the supporting pier. shims should range from 1/8 - 1'' in thickness in order to correct for variations in pier "foundation" hieght.. shims should have enough area to support the total weight bearing on the base plate at completion of the project. grouting is done after the super structure is finished.
10/26/2012 8:15 PM
lyn's correct about doing you're own homework...consider this as your last free-bee.
Register to Reply 7 comments
CaptMoosie (2); durtieduck (2); lyn (1); mmk_er (1); passingtongreen (1)
