Previous in Forum: Shim Pack Size Used Underneth of Column Base Plate   Next in Forum: Free (For Academic and Non-Commercial Use) Civil Engineering Software
37 comments
12 Dots = 5 Lines
10/19/2012 12:48 PM
Using this 12 dots draw 5 lines. No dot should used twice.
Re: 12 dots =5 lines
10/19/2012 12:51 PM
The first law of thermodynamics is you do NOT talk about thermodynamics.
10/20/2012 12:02 PM
A minor editorial subtlety: Your tagline should read, "You caught me, 22!"
--Editor Crankshaft
10/20/2012 12:44 PM
All patched up, boss :p
Good Answers: 918
Re: 12 Dots = 5 Lines
10/19/2012 1:26 PM
Must be more to this puzzle than this, but...
If a line can contain multiple dots...
First line is a horizontal across the top four dots.
Lines 2 through 5 are simply the vertical lines that connect the second and third rows.
That meets the requirements as written in the original post.
10/19/2012 1:32 PM
"That meets the requirements as written in the original post."
Quite. As you are the first to solve, a GA vote! How many correct solutions do you suppose we can come up with?
[edit] As I consider... How do you draw a line using a dot, let alone 12 of them? I would probably select a pencil.
10/19/2012 1:41 PM
OP forgot to include this statement, "without taking the pencil off the paper", which was part of the original puzzle linked by Mizuti.
That would make it more difficult.
Good Answers: 918
10/19/2012 3:12 PM
Not really.
If we assign number for rows and columns (R & C) with 1,1 being the top left, do the following:
Line 1: R2, C3 to R2, C1.
Line 2: R2, C1 to R1, C1
Line 3: R1, C1 to R1, C4
Line 4: R1, C4 to R3, C4
Line 5: R3, C4 to R3, C1
QED
Good Answers: 918
10/19/2012 3:36 PM
Even a simple "S" meets the requirement, too.
10/19/2012 1:42 PM
The requirements state: No dot should used twice.
But! It says nothing about using a dot thrice or not at all!
Victory!
Good Answers: 34
10/19/2012 3:31 PM
A dot can be crossed by a line once only. Victory, is still far away.
10/19/2012 3:37 PM
"A dot can be crossed by a line once only."
Not stipulated in the challenge.
Good Answers: 34
10/19/2012 3:41 PM
OP has erred!
10/19/2012 3:49 PM
OP can't err. It's their puzzle.
10/19/2012 9:37 PM
But as posed, it makes precious little sense.
Good Answers: 34
10/19/2012 10:30 PM
Your observation is pertinent. Thank you, Tornado.
10/20/2012 12:09 PM
As do many posts here.
I liked it. It was simple enough for even I to solve.
Wait, is it "I" or "me"?
I know it sounds better as "me", but with the editor here, I want to be correct.
We may need ER for this.
10/20/2012 12:49 PM
It should be "me" in this case.
--Ed. C.
Good Answers: 34
10/19/2012 10:28 PM
To err is human. And OP is human.
10/19/2012 3:42 PM
Yeah, I checked the Mizuti link and remembered this from a while back.
10/20/2012 12:32 PM
Good Answers: 34
10/20/2012 12:38 PM
The link in post #1 of Mizuti has a few solutions to this puzzle.
Good Answers: 34
10/22/2012 8:54 AM
Will this do?
10/22/2012 9:20 AM
If the OP phrased out the question fully, yes, that's the correct answer
Good Answers: 34
10/22/2012 9:39 AM
Please see my post at #19. I had to copy/paste from your link at post #1 These days, the veterans are choosy about which post to read & which to ignore.
Good Answers: 67
10/23/2012 5:36 AM
yes I agree. GA.
10/22/2012 10:03 AM
One crossing?
10/22/2012 11:53 AM
Somewhere the "end where you started" requirement crept in, which invalidates mine.
This thread provides the perfect example of how you will not get a very good answer if you do not state your question well.
10/22/2012 10:53 AM
7 lines? a bit more interesting. same criteria.
10/22/2012 11:08 AM
10/22/2012 11:35 AM
Good Answers: 34
10/22/2012 11:38 AM
Without lifting pen/pencil.
10/22/2012 11:45 AM
I was using OP post
here's 9 any 10's?
10/22/2012 11:37 AM
8?
10/22/2012 11:50 AM
Is the puzzle to draw 5 lines or 5 line segments? If lines, do we need to utilize at least two drawn dots to establish line?
10/22/2012 12:03 PM
I interpreted a line to be between two points. In this puzzle, each puzzle point is to be a point on a line, or a point at the end of a line. It may not do both. All points have at most two connections. I've been accused of making up the rules as I go, especially if there are no rules. 10?
10/22/2012 12:05 PM
They may not cross, you must use all dots, 11?
10/22/2012 12:19 PM
But a line has no start or stop therefore the only lines that never intersect are parrallel lines. A line segment has both a start and stop, that's why I asked about the rules... its more fun to make up as we go though ;-)
Register to Reply 37 comments
Anonymous Hero (3); Doorman (2); Joshi (8); KP21 (2); lyn (3); Mizuti (5); PFR (7); pritam (1); Tornado (3); Usbport (1)
