Previous in Forum: Replacement VR3 Regulator With VR6   Next in Forum: Generator 3 Phase 4 Wire and Delta-Wye Transformer
250 Watt HPS Light
10/14/2012 10:18 PM
I need a wiring diagram for a 250 watt hps light, the ballast has no x3 connection, the starter has x1, x2, x3. I connected the x1s and x2s ballast to starter, the x3 on starter to light socket the lamp will not light. Thanks for any help.
Re: 250 watt hps light
10/14/2012 10:27 PM
10/16/2012 1:58 AM
What about LVD induction lamp? There are what you want. http://en.lvd.cc/
Re: 250 Watt HPS Light
10/15/2012 3:01 AM
I think LVD ballasts are better than others.
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
web:http://en.lvd.cc/
10/20/2012 8:04 PM
thanks for your comments on the 250 w hps wiring diagram. i went to many wiring diagram sites. i have not found a diagram for a 250 hps ballast with no x3 connection. the 250 w. lights, with no wiring diagram, were removed from a case to install metal halide lighting. please help thanks
Register to Reply 4 comments
cylsue (2); lineman52 (1); wareagle (1)
