hi all,
i am mechanical Engineer i am trying to do small project which is change a Scissor lift from hayraulic to elctrical one and this lift should carry about 4000 kg i start to do the analysis and i met some problems,
i found the force needed and it was very high number.
now i am trying to find the stresses on each arm for the lift i start to find the axial loads on each on and i found them but the problem now is to find the bending moment on each point at the mechanism.
and how to go on find the stresses i need some help
thank you.
