Previous in Forum: Need a Cold Drink Quickly?? Try 3 Phase Fluidization   Next in Forum: Ozone Generators Zap Tainted Vegetables
H20
05/21/2007 12:25 AM
WATER
made up of 2 parts hydrogen and 1 part oxygen
if we break it apart and seperate it
what does it take to put it back
together, does it naturally become water again
what holds it together and if the bond is broken what does it
take to reattach it- just Wondering
LARRICAT -its better to light a lamp than curse the darkness-
Re: H20
05/21/2007 1:33 AM
Hydrogen has the lowest ignition energy of any potential fuel gas. A spark of 0.2μJ is sufficient to set it off. Hydrogen combustion produces water, though at the temperatures normally encountered during combustion it is likely to be as steam, i.e. gaseous water.
Popular Science - Weaponology - Cardio-7
Re: H20
05/22/2007 9:39 AM
At the risk of being overly detailed, you might also remind the questioner that oxygen is needed for hydrogen combustion, either from the separated oxygen, or from another source (air), and that the spark ignition of a hydrogen - oxygen mixture can be very potent! Hydrogen will also "burn" in fluorine, for example.
Good Answers: 101
Re: H20
05/22/2007 12:04 AM
While you know the formula of water as H2O, its actual formula is H-OH, hydrogen hydroxide. Water tends to dissociate into hydrogen (H), which carries a positive charge, and hydroxyl (OH), which carries a negative charge, ions, by itself naturally. This is the basis for virtually all of the chemical reactions involving water (e.g. 2Na + 2H2O = 2NaOH + H2). Water can be broken down into hydrogen and oxygen through electrolysis. It can be recombined by burning and condensing the water vapor produced.
Re: H20
05/22/2007 9:01 AM
If you want to make a pollution free source of energy, electrolyze pure water to hydrogen and oxygen (using energy from nuclear power), then combust the two components back to water. This, of course, is not cheap.
Location: Bolingbrook Illinois, a southwest suburb of Chicago.
Re: H20
05/22/2007 11:24 AM
And also inform the poster that a hydrogen flame produces only UV light, and is invisible to the human eye. Due to the lack of odor, any leak can become a flame source or an explosive environment without extreme care. Watch out for heat ripples in the air.
RichH
"People find it easier to forgive you for being wrong than for being right" J K Rawlings
Popular Science - Weaponology - New Member Popular Science - Cosmology - New Member
Re: H20
05/23/2007 1:28 PM
It takes energy to separate water into Hydrogen and Oxygen.
When they recombine, (which they will do entusiastically at the slightest provocation),
you get that energy back, very quickly.
Careful. It was curiousity killed the cat.
Register to Reply 6 comments
Anonymous Poster (2); Cardio07 (1); DVader1000 (1); NoSciFi (1); Pragmatist (1)
