Previous in Forum: Protection Testing   Next in Forum: Running 220V 50Hz AC System on 220V 60Hz
UPS Issue
10/21/2012 4:33 AM
I was working on 100KVA UPS( BPC Brand) and anytime it switches to inverter mode, the contactor opens immediately in a matter of second displaying overcurrent. i have taken my time to replace virtually all the boards but this kept repeating itself. what could be responsible for this and what is the way forward?
Good Answers: 34
Re: UPS Issue
10/21/2012 5:31 AM
Measure the full load KVA. It may be more.Then, shed some non critical load, then try your UPS inverter. If you still find overcurrent operating, then you have to troubleshoot/calibrate/evaluate your overcurrent circuit.
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
Re: UPS Issue
10/22/2012 5:58 PM
Check you load..
A high current, leading power factor or high harmonics can cause the unit to trip.
At 100kVA I would expect that the UPS is a three phase unit, so check the load balance, this will also likely cause a trip.
What is the load?
Regards,
Sapper
It's all about the Boom! - MythBusters
