Previous in Forum: Hot Tapping on a Seamed Pipe   Next in Forum: Literature About Metal Cracks
Rack and Pinion Question
10/21/2012 11:15 PM
Hello everyone, I am newbie in engineer design and currently have a problem with my calculation. Please if you could help me out.... I am very appreciated it. If you have any other information need to find out....
Question:
How do I calculate (as well as chosing gears size, motors) for our "rack and pinion" system?
Requirement:
- the pinion will move the rack (gear will move the linear gear bar) 0.04 inches in y direction
Known:
- Forces:
Axial Force (object weight): 2000 lbf [includes SAFETY FACTOR (SF) = 1.5 to 2]
Transverse Force: 400 lbf, both normal and tangential [includes SF = 1.5 to 2]
- Speeds:
Transverse: 4 to 10 in. per min. (IPM)
push down speed: 0.2 to 6.0 IPM
- Energy:
Electrical Supply: 220 VAC and 30 amps coming out of the wall socket
Have a great day !!!!!!!!! I need it ASAP
Re: RACK AND PINION QUESTION !!!!
10/21/2012 11:27 PM
Please reformulate correctly.
10/21/2012 11:38 PM
Do you have a cad program?
Rack and Pinion Gears
ATLANTA Gear Racks
10/23/2012 3:23 PM
what CAD program do you talking about? I have CatiaV5 R20...
Good Answers: 21
10/21/2012 11:58 PM
go here and get the information on calculating forces. http://www.atlantadrives.com/pdf/ads_racksel.pdf
10/23/2012 3:31 PM
thank you for helping, I found that one on google too ... but since my linear motion is too short... I wonder is there any other way I can do it?
Re: Rack and Pinion Question
10/23/2012 8:47 AM
Hi, I have an Excel file where I calculated the drive mechanism for an electrical drive system that included a rack and pinion. The file will help you specify the current draw needed, the gear strengths and stresses, motor size, gearbox (if needed) and a clutch (if needed) but it was developed for a 16V max system. I am sure that you could extrapolate to meet your needs. I will send it to you if you send your email address to me.
CR4 Admin - Removed email address. You may share email addresses via the private messaging system.
You can lead a horse to water...
10/23/2012 3:23 PM
I am very appreciated it. *
Again, thanks
* CR4 ADMIN - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Register to Reply 7 comments
Data Management (1); engnewbie (3); fixitorelse (1); lyn (1); Tornado (1)
