Railway Fastening
Fasteners are a critical component of track structure, so naturally, railroads are seeking more robust, longer-lasting and maintenance-free fastening products to bolster track for the long haul.
The fastener designs are economical, easy to install and maintain, corrosion resistant, and quiet under load. They have an inherent design flexibility to meet a wide range of performance specifications. For example:
High or low longitudinal restraint to accommodate various system requirements
High or low lateral and vertical spring rate characteristics to meet noise/vibration requirements for either heavy or light vehicle systems
Rigid, resilient or captive spring clip design to attach the rail to the fastener body
Direct installation capability to concrete slab, wood ties or steel ties
Outstanding electrical isolation for protection of stray current flow
Mitre rail expansion joint fasteners, designed to function with mitre rail joints for bridges and other special applications that require electrical signal or power isolation, corrosion resistance and vibration/noise attenuation
Elements of a baseplate based rail fastening system
1. Screw for fixing plate to sleeper
2. Elastomeric pad supporting rail
3. Tension washer
4. Rail clamp
5. Tensioning bolt
6. Baseplate
Zhonghui Railway Parts Co., Ltd. is specialized in production ,sale, development of railway fasteners, railway works equipment, nonstandard and stainless steel fastener . we has a team established by the knowledge, experience, service enthusiasm, The first-class technology research and development, quality management, production control talented person.
Professional, honest, trustworthy Purpose of serving The most reasonable price, the most complete service, providing the best quality products. Oriented to customer needs, take improve production efficiency and quality for the target, continuous improvement and the introduction of professional and technical, to lay a solid foundation for the enterprise, in order to offer our better, more professional full range of services for customers.
