Previous in Forum: Motor HP to Replace a 10 HP Diesel Drive Engine   Next in Forum: Career Scope After Electrical Engineering Degree?
Electricity Power Backup
11/01/2012 5:51 AM
Hi all.
Where can i get a powerfull electricity backup which can support lights,fan,fleezer and ironing at the same time.please help with name,make and country of origin my client needs its urgently.
regards .
Good Answers: 42
Re: Electricity Power Backup
11/01/2012 8:57 AM
In which part of the world you need it. There are good number of of manufacturers and suppliers available in India.
11/02/2012 7:43 AM
thanks a lot.i need to use it in northern Kenya where generators are not the best solution due to fuel consumption and also want something electrical which can work cool and quiet since generators are very noisy. i will be very happy if i can get a bigger capacity invertor and one that can work perfectly.
Good Answers: 34
11/03/2012 3:27 PM
Use solar power to charge a bank of batteries, driving an inverter to provide power back-up.
11/01/2012 1:39 PM
11/01/2012 3:09 PM
Engineering Fields - Mechanical Engineering - New Member Kenya - Member - New Member
11/01/2012 4:02 PM
I suggest to first find out / estimate the power needs of the lights, fan, freezer and ironing to obtain the correct backup system: not too small and not too big.
Assuming you are in Kenya, check this company.
Technology solves problems we didn't know existed, or didn't realise that they needed to be solved. Tinkering is therefore never pointless.
11/02/2012 4:20 AM
The question is unanswerable, as the location, rating, weight, size, manoeuvring restrictions, voltage, fuel, duration of hire and a whole host of other things need to be considered by the specifier.
Once these are in place, try Yellow Pages (usual disclaimer) and do the rest by telephone.
Register to Reply 7 comments
bett4haze (1); Joshi (1); Kenya 1 (1); PWSlack (1); Randall (1); SolarEagle (1); V.I.Abraham (1)
