Previous in Forum: Restraint Symbol in Ceaser II for U-Bolt Pipe Shoe   Next in Forum: Torque Value
GD2 Value
11/02/2012 1:15 AM
I request someone to enlighten me.
The manufacturers of pump & blower manufacturers give GD2 value in their data sheet.
I referred lot of text books, articles, handbooks, etc,. wherein, there is no specimen calculation available for estimating the GD2 value.
Some information available is that, we need to consider the diameter of impeller.
My queries are:
Is diameter alone sufficient?
Should we not consider the operating parameters viz. - Flow rate, temperature, density & viscosity?
If anyone has got information, please post.
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Good Answers: 137
Re: GD2 Value
11/02/2012 7:24 AM
It depends on the mass and the way it's distributed. For eg a cylinder of a given mass, small length, large dia gives higher MoI than long and thin.
It's just a mechanical property of the impeller, operating parameters don't come into it.
Good Answers: 183
Re: GD2 Value
11/02/2012 2:48 PM
GD² is a measure of part INERTIA. If the part is a cylinder and homogen then it is easy to compute the J value. For a complex geometry and variable density ( for instance cooper wire and iron in a motor rotor) it is better to use the GD² value which is directly related to J.
Re: GD2 Value
11/03/2012 2:20 AM
Thank you both.
I request a sample calculation, which will help me to understand the theory better.
KRN
Good Answers: 34
Re: GD2 Value
11/03/2012 1:28 PM
Register to Reply 4 comments
Codemaster (1); Joshi (1); KRNIYER (1); nick name (1)
