Previous in Forum: Switchgear Book   Next in Forum: How to Install Optocoupler
Electrical Wires LT/HT Safe Distance
11/05/2012 7:44 AM
Greetings! would appreciate link/answer to find me standard safe distance required in LT/HT/EHT (EXTRA HT) CABLE networking, please.
Pathfinder Tags: livewires safe distance
Good Answers: 181
Re: Electrical Wires LT/HT safe distance
11/05/2012 7:56 AM
Why should I in the UK look for your local codes in Pakistan. Try having a look yourself.
Good Answers: 42
Re: Electrical Wires LT/HT Safe Distance
11/05/2012 11:46 PM
See: IEC 61936-1 or National Electric Safety Code [IEEE C2-2007 ] ch.124. Guarding live parts
Julius
11/06/2012 12:15 AM
Thank u for sharing info. we at work use phrase "safe distance" alot. For live wires i heard 6 to 10 feet is must keep dist. This statement exist as word of mouth no specifically mentioned( as in my knowledge so far) so put this query at forum.
11/06/2012 3:23 AM
That's good advice.
Good Answers: 42
11/06/2012 1:57 AM
Nevertheless the word "cable" generally could means "stranded wire" [electrical or mechanical] by word "cable" one usually understands "insulated wire or cable".
If you need to know the safety distance between overhead transmission lines live [bare] conductors this is not connected with my answer, indeed.
In my opinion, does not exist any standard rule for this. One has to calculate the slack in all configurations [taking in consideration the span and the load-ice, wind and so on].
The minimum gap has to be compared with the minimum required for air withstand BIL-also in possible pressure and temperature.
Julius
Good Answers: 34
11/07/2012 2:38 AM
Register to Reply 6 comments
7anoter4 (2); Butterfly2 (1); Joshi (1); PWSlack (1); TonyS (1)
