Previous in Forum: Stanchion   Next in Forum: Instrument Calibration
Transmitter
11/07/2012 7:23 AM
Hi All,
Is it necessary to ground the instrument???
REgard
Re: trnsmitter
11/07/2012 7:30 AM
  • Not if immunity to electromagnetic interference is not needed.
  • Not if immunity to the effects of earth-loop currents is not needed.
  • Not if protection from the effects of static electricity is not needed.
  • Not if operation of the circuit protective device(s) during a fault event is not needed.
  • Not if protection against electrocution is not needed.
  • Not if compliance with national electrical codes is not needed.
  • Not if it is a non-electrical instrument and the equipment is grounded elsewhere.
  • Not if there is no electrical connection to the plant.
  • Not if it is on some form of vehicle that is insulated from ground/earth potential.
  • Not if it is made of non-conducting materials.
  • Not if it is CE-marked as double-insulated.
  • Etc.
Re: Transmitter
11/07/2012 1:55 PM
What do the manual and manufacturer application notes say?
Re: Transmitter
11/09/2012 4:17 PM
"Is it necessary to ground the instrument???"
Perhaps, perhaps not. There are many reasons for grounding and for not grounding things. It would help a whole lot if this one had a clue about what that one is doing.
It might also be beneficial if that one had a clue.
Have FUN!
TT3
If the software can detect, compensate, avoid, or correct an anomalous condition in the system, it is, by definition, a software problem-regardless of the root cause. In the long run, for most classes of problems, it is cheaper to fix it in the SW
jack of all trades (1); PWSlack (1); Turbotroll3 (1)
