Previous in Forum: Type Test of LV Switchgear Assemblies   Next in Forum: IEC Standard Code for Electrical torquing
In Panel Rating
11/08/2012 3:02 AM
Can anly please help me out by explaining " What is InPanel rating? . how Do I select the breaker rating for a incomer feeder based on the panel inpanel rating .
Wheather this Inpanel rating needs to be calculated both for LT as Well as HT Panels ?
Pathfinder Tags: Inpanel rating
Re: In Panel Rating .
11/08/2012 3:10 AM
By following the protocols in British Standard 7671.
11/08/2012 5:38 AM
Kindly explain is INPanel Rating .
11/08/2012 7:17 AM
Q1) Where has the term come from?
11/08/2012 7:59 AM
National Electrical Code.
Never heard of Inpanel rating. You may need some help translating.
Good Answers: 170
11/08/2012 8:30 AM
It is something similar to the Enclosed Thermal Current (Ithe)
Good Answers: 804
Re: In Panel Rating
11/08/2012 10:39 AM
Are you sure it isn't I<sub>n? That would denote I (current) n (nominal or normal). Basically that would just say that someone wants to know the current rating of the panel, but not based on the connected load, overload capability or short circuit current rating. Just "what is it rated for?".
Good Answers: 804
Re: In Panel Rating
11/08/2012 2:50 PM
I was posting from an iPad so no access to formatting.
In = Continuous current rating per IEC 60947-2
Register to Reply 7 comments
electricalexpert65 (1); JRaef (2); lyn (1); PWSlack (2); satnat.2008 (1)
