Previous in Forum: Steam Turbine Efficiency in Combined Cycle Plant   Next in Forum: Flow Rate Possible Fuel vs Air Medium
Interpretation of UCS 11(b)2
11/09/2012 1:25 AM
Hi,
ASME BPV Sev VIII Div-1 UCS11(b)2 states that "Carbon or alloy steel nuts and carbon or alloy steel washers of approximately the same hardness as the nuts may be used with alloy steel bolts or studs for metal temperatures not exceeding 900°F (480°C)."
Is it mean that, below 480 Degree Celsius, if the hardness are same, then we can use CARBON steel nuts and washer with ALLOY steel bolts or studs?
Thanks
Good Answers: 34
Re: Interpretation of UCS 11(b)2
11/09/2012 2:10 AM
It does mean that.
11/09/2012 5:10 AM
Isn't steel itself an alloy?
11/09/2012 7:37 AM
Carbon steel is steel where the main interstitial alloying constituent is carbon. The American Iron and Steel Institute (AISI) defines carbon steel as the following: "Steel is considered to be carbon steel when no minimum content is specified or required for chromium, cobalt, molybdenum, nickel,niobium, titanium, tungsten, vanadium or zirconium, or any other element to be added to obtain a desired alloying effect; when the specified minimum for copper does not exceed 1.04 percent; or when the maximum content specified for any of the following elements does not exceed the percentages noted: manganese 1.65, silicon 0.60, copper 0.60."[1]
Alloy steel is steel that is alloyed with a variety of elements in total amounts between 1.0% and 50% by weight to improve its mechanical properties. Alloy steels are broken down into two groups: low-alloy steels and high-alloy steels. The difference between the two is somewhat arbitrary: Smith and Hashemi define the difference at 4.0%, while Degarmo, et al., define it at 8.0%.[1][2] Most commonly, the phrase "alloy steel" refers to low-alloy steels.
Every steel is truly an alloy, but not all steels are called "alloy steels". Even the simplest steels are iron (Fe) (about 99%) alloyed with carbon (C) (about 0.1% to 1%, depending on type). However, the term "alloy steel" is the standard term referring to steels with other alloying elements in addition to the carbon. Common alloyants include manganese (the most common one), nickel,chromium, molybdenum, vanadium, silicon, and boron. Less common alloyants include aluminum, cobalt, copper, cerium, niobium, titanium, tungsten, tin, zinc, lead, and zirconium.
Source:Wikileaks :-)
11/09/2012 7:39 AM
It's perfectly clear now. Thanks.
11/09/2012 7:48 AM
So, is that a yes, or a no?
Good Answers: 75
11/10/2012 7:31 AM
'Every steel is truly an alloy, but not all steels are called "alloy steels"'
Yet they use the elemental name of iron for cast iron (2.1-4.0% C & 1.0-3.0% Si) and pig iron (3.5 to 4.5% C) which are also technically alloys and therefore should not bear the elemental name.
Register to Reply 6 comments
Joshi (1); lyn (1); masu (1); PWSlack (2); sanweld (1)
