Previous in Forum: Brushless Generator Exciter Stater   Next in Forum: Phase Nullify in the Electric Bus
Control Panel Wiring
11/09/2012 1:53 PM
can somebody explain control wiring indian / IEC standard ? i am looking forward for the standard which explains different types of ferrules which are used in 132/33/11 KV substations such for cts / pts/ auxilary wiring in control panels.
Re: control panel wiring
11/09/2012 2:07 PM
Check these: IS 3231; 1248; 2419; 2705; 3156; 375; 8686
Re: Control Panel Wiring
11/10/2012 2:55 AM
Some of the pdf circuits are not easy to read, some have errors, this is mainly due to the importing of schematics from an older ORCAD Dos Version. I have corrected some circuits, some are to be checked. Also some circuits were not corrected after they were drawn by New Learners, as i wanted them to document what they learnt and familiarize with computers, Some did a good job. This section has no electronic parts, so you can figure out the diagrams.
The Control Panel on the right is a Multi Zone Temperature Control panel used in Plastic Extrusion Moulding. We made many of these and it helped us learn cable management techniques. The panel is a standard way it was built and some of the merits were the selection of panel components and wiring expertise.
Just like rackmounts hold big instruments or computers, control panels small or big have to hold DIN Instruments, switches and annunciators to make it easy for the operator. The maintenance work also is simple from the backside. It can be kept near the machinery which it controls.
Some Control panels go into Control Rooms at a distance away or at a greater height from the shop floor. This way they can monitor and give instructions while managing a larger process like processing of chemicals and at the same time safeguarding the instrumentation and computers with controlled
11/10/2012 3:56 AM
Are you hallucinating, or just delusional? Or, both?
Good Answers: 34
11/10/2012 8:50 AM
Both, for sure.
Register to Reply 4 comments
jmmyadam (1); Joshi (1); lyn (2)
