Previous in Forum: Summer Heat Storage for Winter Use   Next in Forum: How Do I Find The Corners of My Lot With Only 2 Known Corners Using GPS?
Tire Solution After Sandy
11/10/2012 12:44 AM
guru
your tire wall would function as a great seawall would it not? IM in sales would enjoy running with the ball. mo the mule
Good Answers: 34
Re: tire solution after sandy
11/10/2012 1:21 AM
Do enjoy running with the ball then.
11/10/2012 2:57 AM
Hello Friend!
Are you often filled with the desire to stimulate a discussion, to romance an idea, to ravage a concept through all its titilating intimacies?....Only to be disappointed time and time again by the inadequacy of you tiny diction?
Is your diction so limited that it fails to convey the thrust with which you desire to convey your idea?
Is your diction so insufficient that your attempts to penetrate a discussion with driving impact (in hopes of seeding a productive development) are ignored, or worse, unnoticed?
If so, you are likely suffering the effects of micro-diction, sometimes called ED (elocution dysfunction). Micro-diction can have many causes but is often correlated to a limited lifetime engagement in reading books.
It is important to note that multilingual individuals may show signs of micro-diction in one language while wielding an impressive fertile diction in another language.
The good news is that Micro-diction can be overcome. With the proper exercises, encouragement and practice, your diction will increase in size and strength.
You won't have to worry that others will point and laugh at your inadequate diction, and engaging in productive conversation can be pleasurable once again for you and your partners!
11/10/2012 11:28 AM
I read once that people who suffer from inadequate diction can compensate by becoming cunning linguists.
I'll just go ahead and off-topic myself.
11/10/2012 4:17 PM
Quite
hard on
yourself...
My vote is for on-topic.
11/10/2012 4:00 AM
mo,
Run; run far away. Don't look back. Keep going. I'll let you know when to stop.
11/10/2012 6:40 AM
Good Answers: 179
Re: Tire Solution After Sandy
11/10/2012 10:48 AM
I haven't a clue where the OP is going with this....except mentioning Sandy.
Cum to think of it, I once knew a gal named Sandy. Oppps, never mind!
Register to Reply 7 comments
CaptMoosie (1); Joshi (1); kramarat (1); lyn (1); truth is not a compromise (2); Usbport (1)
