Previous in Forum: Busbar and CT Ratio to Follow AF or AT of a MCCB?   Next in Forum: Surge Suppressors Operation
CT Connection for Differential Relay
11/12/2012 12:32 AM
Dear all
If we have power tr. Delta/star & we need to connected differential relay the question is if we connected the current tr. At delta side for power tr.delta and star side for power tr. Star what will happen .
Also if we connected CT for both side star or both side delta what will happen .
Regards
Good Answers: 34
Re: CT connection for differential relay
11/12/2012 1:22 AM
Are you idle & just speculating? What is your real problem, not imaginary one?
Re: CT Connection for Differential Relay
11/12/2012 10:10 AM
What will happen? well, without additional circuitry tied on downstream, the insulation on the CT wires runs the risk of breaking down. It's a bit like asking what happens when a train passes a red signal.
Good Answers: 131
11/13/2012 10:33 AM
The CTs need to be connected per the requirements of the particular differential relay(s) you are using. Consult the instruction manual to determine what they want.
The older style electromechanical and solid-state numerical differential relays required the CTs to be connected in wye configuration on a delta winding of the power transformer and delta-connected on a wye winding. This cancelled out the phase shift inherent in a delta-wye transformer's primary to secondary waveforms. If you connect the CTs as you have described (delta to delta and wye to wye), you will trip the differential relay very quickly as load is applied to the transformer.
Modern microprocessor-based relays do an analog to digital conversion of the currents, so they can compensate for the phase shift mathematically. Those relays typically want you to connect all the CTs in wye configuration, and then you tell the relay what the transformer's winding configuration is (or it may even detect the phase shift and compensate automatically).
11/13/2012 4:41 PM
Thank you very much
Good Answers: 131
11/14/2012 8:23 AM
Note also that if your relays require a delta CT connection, the order of the delta (the order of the connection of the delta - which phase polarity end connects to which phase's opposite end) matters. Again, the manufacturer's instruction manual will guide you.
FADHEL (1); Joshi (1); PeterT (2); PWSlack (1)
