Previous in Forum: Type Tested Panel   Next in Forum: Optical Cable
9 comments
110V AC Mobile Charger Connect to 230V AC
11/12/2012 6:15 AM
Firstly Happy Diwali TO All of you. I have a mobile charger having Input 110V AC & Output is 1.5V DC. What will Happened if i connect it to 230V AC Input? Would it work or not? If yes How it will work? Thanks.
Re: 110V Ac mobile charger connect to 230V Ac.
11/12/2012 6:29 AM
Well, that would depend rather a lot on what it says in the manufacturer's instructions supplied with it, which cannot be seen from here. One of the possibilities is a brief firework display, with which one might celebrate Diwali.
11/12/2012 6:33 AM
The charger label should specify the range of input voltages with which the charger will work.
If you apply a voltage higher than the specified range, the charger will probably release the magic smoke that keeps it working. It may also emit a loud noise. In the worst case, pieces of it may fly in all directions.
11/12/2012 6:40 AM
1-it's not a mobile sharger.
2-it will burn out.
11/12/2012 7:07 AM
OP didn't say it was a mobile sharger .
Good Answers: 44
11/12/2012 8:05 PM
The topic created by the...um...OP...states "mobile charger"
Maybe he's charging mobiles?
Why you smarmy in AP mode, bro?
11/12/2012 8:26 PM
Was pointing out to abootorab that the original poster (... um...OP...) did not state "mobile sharger" - drawing to light the fact that the OP did state "mobile charger". Yea?
Thought it better to stay anon. and off topic - but since you asked.
Good Answers: 44
11/13/2012 11:26 AM
Oh...sharger...yes, I see.
11/12/2012 8:36 AM
If the plug on your mobile charger fits the outlet socket you have, plug it in. What's to lose, except the magic smoke.
India - Member - New Member
Good Answers: 164
Re: 110V AC Mobile Charger Connect to 230V AC
11/12/2012 5:53 PM
Most electronic devices work ok with all voltages in the world. My PC, mobile phones, iPod,iPad ... all have chargers which are rated 110 - 240V. So, if you already have a charger, check it out, it may be directly suitable, or sometimes there may be a selector switch. You need an inexpensive adaptor to make the pins fit into the socket.
Register to Reply 9 comments
abootorab (1); Anonymous Poster (1); cuba_pete (2); JohnDG (2); kvsridhar (1); lyn (1); PWSlack (1)
