Previous in Forum: Vapor Pressure of Natural Gas   Next in Forum: Compressor Oil Filtration
Powerpack Question
11/12/2012 7:58 AM
We had a Power pack of 210 lts capacity operating under a pressure of 90 kg / cm2 (Pressure regulating valve setting is 90 kg/cm2 ),for this we had accumulator too. During the Idle time Pressure is dropping upto 70 kg/cm2 and after that pressure is making upto 90 kg/cm2.
There is no External Circuit Leak.
Pl Suggest the Solution
Regards
Nithin
Re: Powerpack
11/12/2012 8:01 AM
  • Check the non-return valve fitted between whatever is producing the pressure and whatever the pressure indication is coming from, for it looks like it is letting by.
  • Check also the kick-in and kick-out points on whatever is producing the pressure.
Chances are, it will be one or both of them.
Good Answers: 21
Re: Powerpack Question
11/14/2012 1:28 AM
You didn't say if the pressure valve was an unloading valve or a standard pressure reducing. Under normal circumstances a system with an accumulator will have a un loading valve in the system. The check valves wear and begin to leak back causing the loss of pressure. The unloader then kicks in and pressure then is increased to set point. Check these items and see. Other wise consult a hydraulics person to help you.
Fixit
India - Member - New Member
11/16/2012 9:55 AM
thank u fixit , same think I am suspecting , but by trial and error method only we can conclude i.e by replacing it with new unloading valve . is there any better way to clarify Regards Nithin
When Emotions runs high ,Intellectual wont work
11/22/2012 6:59 AM
What would be the difference between pressure reducing and unloading valve.
Good Answers: 137
11/14/2012 8:36 AM
When you say There is no External Circuit Leak, do you also mean there is no oil being supplied to equipment? If there is, that's where the oil is going.
Codemaster (1); fixitorelse (1); P.Nithin Kumar (2); PWSlack (1)
