Previous in Forum: Difference Between Ultrasonic & Radar Level Transmitter   Next in Forum: Hydrodesul Question
Load Calcualtion for Car
11/13/2012 5:58 AM
Hi , freinds
I need to find the heat balance for a car , i consider
area of the car,
- Sunlight
- Engine heat
- Road heat
- Transmission
- Exhaust heat
but since its about educational purpose i need some precise information of calculating the load ?
Re: load calcualtion for car
11/13/2012 6:02 AM
This is one for lyn.
11/13/2012 7:00 AM
Oh, thank you.
Let's take them one at a time:
area of the car, This is very important. I live in a desert area, which is very hot. That means a higher heat load than if the car is in a cold area. So, hot area=high heat load. Cold area= lower heat load. You'll need to define the area of the car.
- Sunlight This is more important in the daytime than at night. It is also somewhat dependent on the area of the car, as described above. Daytime=higher heat load. Night time= lower heat load.
- Engine heat This is also related to area, but not so much. You will need to define the state of the engine. On, or off. On=more heat. Off= less heat.
- Road heat Not important. Only affects the bottom of the car. Bottom=hotter. Top= cooler. Averages out from top to bottom.
- Transmission Heat goes to radiator, if car is so equipped. But you don't list radiator as a potential heat source, so not included in calculations.
- Exhaust heat This is of no concern to you, and would only affect people who are too close in the first place and should BACK OFF anyway. Close= hotter. Far away=cooler.
I would consider much more if I were the student, but I'm just an old man and have read the FAQ'S of this site. Especially the part about homework.
A Simple Method to Calculate Vehicle Heat Load
Register to Reply 2 comments
