Previous in Forum: How Does High Def. Sync with TVs Capabilities?   Next in Forum: Buy Voltage Regulating Control Relay KVGC202
Engineering Fields - Electrical Engineering - Electrical Engineer
Industrial Earthing
11/14/2012 1:11 AM
In Factories/Industries, we provide an earth mat at foundation plith level and connect PEB Column(Structrual Columns) to the earth mat. May i known Why it is really for?
IS there any standrads for it? (Email Address Removed. CR4-Admin)
Pathfinder Tags: Industrial Earthing
Good Answers: 34
Re: Industrial Earthing
11/14/2012 2:07 AM
Some LINKS among these has your answer.
11/14/2012 2:52 AM
this may help you.
grounding Grids Design
11/14/2012 3:13 AM
British Standard 7671 may be purchased from BSI outlets over the internet or by telephone using a credit card.
The only purpose of earth conductors is to operate the circuit protective devices in the event of a fault, thereby protecting lives and property.
E-mail address posting reported to admin for attention.
11/14/2012 10:35 PM
The purpose of bonding all metal parts of the building together is to reduce the voltage potential between parts.If all parts are grounded to a common point, the voltages induced by a lightning strike are safely shunted to ground.This also has the benefit of reducing noise that can be induced by structural parts at different potentials.
The ground also serves a critical function in the event of a current fault to ground by providing a low resistance path to trip fault detection equipment or circuit breakers.
All grounds should terminate at a common point.
Register to Reply 4 comments
HiTekRedNek (1); Joshi (1); nobodysomebody47 (1); PWSlack (1)
