Previous in Forum: Buy Voltage Regulating Control Relay KVGC202   Next in Forum: Groundig Resistance
16 comments
Induction Motor No-Load Current
11/14/2012 3:36 AM
Apart from getting the data from the motor manufacturer or from actual measurement, is there a way to calculate the motor no-load current of an induction motor?
Pathfinder Tags: Motor No-load Current
Re: Induction Motor No-Load Current
11/14/2012 3:41 AM
As it's just a phone call, why bother <rhetorical question>?
Good Answers: 34
11/14/2012 4:21 AM
Yes.
11/14/2012 8:49 AM
Indeed there is. Supply voltage minus motor back-EMF all divided by winding resistance springs to mind. The challenge is to measure the back-EMF...
11/14/2012 4:39 AM
If you really want a meaningful figure then measure it or contact the manufacturer.
You can do reams and reams of calculation which will probably bear no relation to reality.
I just don't understand why some people would rather believe pages of calculation rather than actual measurement.
I had a rep in the other day who was trying to estimate the torque I needed on my pump by working backwards from the torque provided by an overengineered motor gearbox fitted by someone else. The result was over 50% out.
It took me 15 minutes to screw a bar onto the pump rotor, add weights until it turned and come up with a real world result.
What is calculated and written on paper doesn't necessarilly effect reality.
11/14/2012 4:49 AM
Absolutely amazing, isn't it?
11/14/2012 7:39 AM
Certain types of people seem to think that there should be formulas and calculations for everything.
Electric motors is a fine example of this mindset.
Good Answers: 137
11/14/2012 8:30 AM
Not sure whether you'd call it a calculation, but I think it's about 20 - 25% FLC. (that's from memory, somebody might say it's wrong %). No-load current is higher than you might expect as the power factor is much lower on no load.
11/14/2012 11:44 AM
I would put it 8-80% of the FLC, depending on an induction motor type, size, etc.
Good Answers: 804
11/14/2012 11:54 AM
What I find interesting is that this question comes up quite a bit in this and other forums I frequent. I keep wondering why people seem to think this data is remotely important to know in advance (as opposed to measuring it after the fact). I see no value in it as advanced data, only empirical data, i.e. to know if a shaft or belt is broken maybe.
11/14/2012 12:06 PM
We are dealing with the mindset that everything in the world can be put into a formula and calculated, regardless of the real world practicality of the calculations.
In that world, logic does not apply.
11/14/2012 1:10 PM
Yup, I'd love to know if that sort of mind simply stalls when confronted by a boomerang.
Mind if it whacks 'em on the head it will certainly stall.
11/15/2012 8:57 AM
Good Answers: 244
11/15/2012 5:52 PM
Here is some information:
No Load current: 1/3 of full load (Thumb rule), generally between 20% and 40%
No Load Power: Almost 8% of the Motor Capacity
No Load Power Factor: 0.2 - 0.3
Locked rotor current: 4 - 6 times of full load current
Locked rotor Power Factor: 0.2 - 0.4
-MS
11/16/2012 12:20 AM
Thanks for your answer.
11/16/2012 3:02 AM
I find the concept of 'No Load Power' a tad confusing...
A bit like those supermarket special offers you see when there's no product on the shelf.
Good Answers: 137
11/16/2012 7:21 AM
No-load power is the power drawn from the mains. Obviously the output shaft power is zero at no load. Can't see anything confusing.
Register to Reply 16 comments
Codemaster (2); Joshi (1); JRaef (1); lyn (2); Mohamed Akram Khan (1); msamad (1); PWSlack (3); SHOCKISCAN (1); user-deleted-1105 (3); Yuri B. (1)
