HI all,
I would like to start a discussion on the Differential Pressure based Level measurement in the Re-boiler.
The Process fluid vaporizes and settles down as
condensate in the LP Leg of the Transmitters to give a drift in the reading.
The following steps have been carried out:
1.
Installation of the Condensation Drain POT - Volume of condensate formed
during the operation is high and has to be drained frequently.(Heat tracing
could give a 40 deg Celcius which wouldn't solve the purpose).
2. Wet Leg
installation using Glycol - The installation has proven unsuccessful with this
process condition.
3.
Using Condensate as Fill Fluid and reversing the Legs - Couldn't provide
Consistent Continuous measurement.
Does any one have any suggestions other than this.
Attached is the sketch of current installation.
There are totally five DP transmitters and I tried to replace one of them with a capillary transmitter and receiving a proper stable reading.
Couldnt replace all the four of them now. So should work with this DP transmitter for some time now.
Awaiting your valuable suggestion.
Regards,
Shan
