Previous in Forum: Why DC Supply is Preferred for Transmitter or Sensor Switches   Next in Forum: DP Level Transmitters in De-Ethanizer Re-Boilers
Level Transmitter Displacer Type
11/12/2012 2:49 AM
hi every one
i am doing some research on level transmitter displacer type i have some question.
i need to use it in interface application but in manual it says the displacer must always immersed in upper fluid. i want to know how can i be sure that this will happened.
i have even read the calibration article that said how to calibrate it . but there is no guaranty for displacer about being immersed in upper fluid.
please help me.
Good Answers: 34
Re: level transmitter displacer type
11/12/2012 3:25 AM
What make & type, of displacer type level transmitter, you are referring to?
11/12/2012 3:29 AM
Probably one that must be immersed in the fluid it is measuring.
11/12/2012 4:08 AM
That's a good possibility.
Engineering Fields - Instrumentation Engineering - New Member Engineering Fields - Control Engineering - New Member Technical Fields - Technical Writing - New Member Technical Fields - Education - New Member Fans of Old Computers - Apple II -
Good Answers: 46
Re: Level Transmitter Displacer Type
11/15/2012 8:39 AM
The manual is correct: the displacer must be fully submerged in the process liquid(s) in order to measure the interface between two liquids. If it were not, there would be no way to discriminate between a change in interface level versus a change in total liquid level.
This is really a process control problem, not a transmitter problem. The solution is to fix or regulate the total liquid level so that it will not fall below the upper nozzle height of your interface level transmitter. A second level transmitter and control loop sensing total liquid level (above the interface transmitter) could be used to regulate total level so that it would never fall down into the range of the interface transmitter. Alternatively, an overflow pipe or weir could be used in the process vessel to ensure that the total liquid level must remain above some fixed point above the interface transmitter.
Without knowing anything about the process vessel, the liquids involved, or the application, it is impossible to prescibe a practical solution for you.
They call me "lightning" when wielding a hammer, because I never strike twice in the same place
Register to Reply 4 comments
Joshi (1); lyn (1); PWSlack (1); tonykuphaldt (1)
