Previous in Forum: What is Bus Post Insulator?   Next in Forum: Power Connection to Stepper Driver
Power Distribution Control System
11/22/2012 6:50 AM
What are the required steps for writing a Pre-commissioning & commissioning procedure for a power distribution control system (by Schnieder). Any information will be helpful> i have written a highlighted some points from my initial experience on an Electrical control systems. Just want to be sure am not missing any points. Your views will be appreciated.
Thank you
Re: Power distribution control system
11/22/2012 7:21 AM
Precommissioning is "does it agree with the drawings and is it safe to energise?". Commissioning is "does it power-up safely and work according to the Control Philosophy?". Without those documents, one cannot do it properly.
The procedure can be as simple as stating the marking-up those documents for revision on the basis of what is right and what is wrong. Without further information it is difficult to say much more.
Good Answers: 102
11/22/2012 11:08 PM
Ditto PWS.
$chneider....should have a commissioning proforma in the box/crate it came in.
Re: Power Distribution Control System
11/22/2012 10:00 AM
11/22/2012 11:11 AM
You know that those big companies usually make software that save a load of work paper in making those assessment´s ... unless you have a very specific case in your hand´s, they will give you a very good idea.
“For no man can forbid the spark nor tell whence it may come.” ? Francis Bacon
11/23/2012 5:34 AM
11/27/2012 5:59 AM
not sure if I get what you mean, but if you are (or want to) working in this are, check the data in the end (software may have flaws)
Register to Reply 6 comments
Anonymous Poster (1); electronick (2); lyn (1); PWSlack (1); Wal (1)
