Hi all
Will you please help me on this,
I am designing avr for ac generator single and three phase, the input voltage is 180-240 vac, and the output is 100 vdc.
I came up with relay type avr, which made by placing the normaly closed contact of the relay in parallel with the thyristor. when the volts build up, the relay will energize and the contact will be open so the avr will control the output by varying the firing time of the thyristor gate.
my question is how to make the voltage build up without using relay contact ? is there any other way maybe by using a semiconductor to use instead of the relay?
hope you got what i mean and thanks for your help
