Previous in Forum: Chemical Attractant for Mosquitoes   Next in Forum: How to Produce Hydrogen
Pattern in Valve
11/23/2012 5:52 AM
All,
What is the real difference between short and long pattern for valves (practical)
Short pattern valves are generally avoided. What is the reason for this.
Thanks
Achieve anything in Life just by Hard Working alongwith Smartness
Re: pattern in valve
11/23/2012 7:06 AM
One cannot lag the pipeline properly if the valve handle is under the lagging. Also, a valve handle that is under the lagging is rather difficult to operate...
11/23/2012 7:44 AM
Valves for cryogenic service are generally long-pattern. The reason is twofold:
  1. It enables the handle to continue to be available for use despite the usual football-sized chunk of atmospheric-moisture-ice that inevitably builds up around them, and
  2. It reduces the risk of the operative getting frostbite while operating it.
Good Answers: 67
11/25/2012 8:45 AM
GA. One more reason for its use in cryogenic service is:
- It enables the handle to continue to be available for use despite the thick layer of insulation (some times up to 250 mm) to reduce heat in-leak which causes vaporization loss in cryogens.
11/23/2012 10:00 AM
The master standard for face-to-face dimensions is ISO 5752.
The Function of Ball Valves Used in the Oil & Gas ... - PDH Center
Register to Reply 4 comments
lyn (1); pritam (1); PWSlack (2)
