Previous in Forum: Attention: Automotive Engineers   Next in Forum: SOS
14 comments
Properties of En8 steel
05/22/2007 11:18 AM
Plz can anyone can give the properties of En8 steel. Here En stands for English and 8 stands for percentage of carbon.
Re: Properties of En8 steel
05/22/2007 11:54 AM
Hi, I reserve the right to be wrong on this...but.
Many years ago (25-30!) I was looking for the nearest thing to medieval steel to make a reproduction crossbow.
I seem to recall EN8 was the closest I could find, it is a low carbon steel but higher than 'run of the mill' mild steel, it can be hardened and tempered into a good spring, I still have the roughly formed bow in my garage, it never got finished!
I think the EN... type grading is now obsolete or if they do exist it is probably Euro-Norm, whereas it probably stood for something else originally!
Hope this helps.
05/22/2007 12:02 PM
I hope some of this helps, at least to search for more info.
BS 970 080M40
(EN8) A medium strength steel. Suitable for stressed pins, shafts studs, keys etc. Available as rolled or normalised. Supplied as square bar, or round bar or flat.
Subcategory: Carbon Steel; Medium Carbon Steel; Metal; British Designations
Key Words: EN8
Material Notes:
This British mild steel is very similar to the American AISI 1040 mild steel. Please refer to AISI 1040 for additional properties.
09/01/2009 6:07 AM
Dear Sir,
Subject: Carbon Steel EN-8
Presently we require EN-8 Carbon Steel Wire Rod 8.1mm Bright Finish prime. Quantity 20 MT. Kindly sends your best prices at C&F Karachi Pakistan.
Table Symbol of class and chemical composition.
Chemical Composition
Symbol C Si Mn P S
S 40 C 0.37 to 0.43 0.15 to 0.25 0.60 to 0.90 0.030 max 0.035 max
If you have any further information / clarification please contact us.
Thanking you for your Co-Operation.
Thanks
Muhammad Arif
05/23/2007 3:11 AM
Type Of Steel: Constructural; BS Spec (BS970): 080M40; Composition: 0.4% C 0.8%Mn; Condition: HR -> CD (thin); Yield Stress x 106 Pa: 530; Tensile Stress MPa: 660; Elongation %: 7.
From http://www.roymech.co.uk/Useful_Tables/Matter/Strength_st.htm
04/25/2008 3:43 AM
  • en8 steel - induction hardning - 50 ~ 55 HRC
  • C - 0.4% & Mn- 0.8%
varroc group
pune
Reply Off Topic (Score 6)
05/23/2007 6:33 AM
To the best of my knowledge, it is similar to AISI 1040, a general purpose axle material.
Good Answers: 243
05/23/2007 10:18 AM
Not quite sure how 8 = .40 carbon, but thats probably another thread...
You should define whether or not you need cold drawn or hot rolled material.
En8: Chemical Composition Grade 080M40 Standard BS 970-1 Country Great Britain Heat Analysis Element Symbol Min. Max. Carbon C 0.36 0.44 Manganese Mn 0.6 1.0
milo
10/13/2007 5:27 AM
Hello Milo, By chance you havn't got the new number for HT45? Very simular to En8 but was harder from what I remember! If not, not to worry!
Good Answers: 243
10/13/2007 8:20 AM
Good morning Mr Truman Brain.
I do not have any info on this steel in my immediate reach.
I found one reference online that someone is calling it a tool steel.
http://www1.wilsonmfg.com/rotarydies.php
However I could not confirm it at Crucible or in metalinfo.com.
I am currently travelling in Tucson AZ USA and so unable to hit my printed references back at work and home. I will be back next thursday. Until then, perhaps a call to the folks at Wilson above may help you.
Thanks for the query!
milo
03/03/2008 7:29 AM
My understanding of the designation EN for steel is that it stands for "emergency number" and was created around 1939 or so to standardize steel in Britain during wartime. Prior to this standardisation steel was described by carbon content etc and also by the name of the mill or producer. This was confusing and needed to be sorted out so that engineers could communicate specification. I was told this by an old engineer who remembered the pre-EN codes. The system was useful through the war years and was due to be reviewed and updated after the war. It never happened and we still refer to EN numbers.
07/02/2009 2:06 PM
i hope it may help....
EN8 mild steel was first used at time of second world war. And here EN refers to Emergency Number and 8 is further subscript to identify. It is a low carbon unalloyed steel and is used greatly in Britain
12/17/2009 11:57 AM
EN 8 is used extensively in the manufacture of vehicle side shafts. It is first stamped or forged into an approximate shape, heat treated to normalise the grain, machined to size and splined. The component would then be induction hardened.
12/08/2010 11:40 PM
EN8 Steel
EN8 also know as 080M40. An unalloyed medium carbon steel. EN8 is a medium strength steel, good tensile strength. Suitable for shafts, stressed pins, studs, keys etc. AISI 1040.
Available as normalised or rolled. EN8 is supplied as round drawn/turned, round hot rolled, hexagon, square, flats and plate.
BS 970 1991
BS 970 1955 EN
AISI/SAE
Werkstoff
080M40EN8
1040
1.1186
080A42EN8D1042-
We can also supply EN8D - 080A42 bar with hard chrome plating.
Popular size ranges shown below, other sizes available upon request.
Specification BS 970: 1955
Chemical CompositionBS 970:1991/1983 Nearest Equivalent
CSiMnNiCrMoSP
En8
0.35/0.450.05/0.350.60/1.00---0.06Max0.06Max080m40
05/16/2016 6:54 AM
Thanks for information guys...very nice information about EN8 Steel.
Neo Impex
Anonymous Poster (6); Milo (2); Mr. Truman Brain (1); Nachi (1); neoimpex (1); Randall (1); user-deleted-1105 (1); vhk.314 (1)
You might be interested in: Stands and Supports, Stainless Steel Alloys, Sheeters
