Previous in Forum: Calculate Fan Capacity   Next in Forum: Shoe Bottom Temperature
To Find the CC of an Engine
11/24/2012 12:52 AM
hi guys,
My question is about cubic centimeter of an engine like 800 cc or 1200cc
plz inform me any one that what the basic formula to calculate the cc of an engine
plz help me in solving this problem.
thanks
Re: To find the cc of an engine
11/24/2012 1:41 AM
bore x stroke. bore- pi [3.14] x radius[of bore] squared . your in the wrong thread.
Good Answers: 34
11/24/2012 2:27 AM
The volume in cc of the space between the bottom dead centre & top dead centre of the piston.
Good Answers: 53
11/24/2012 5:45 AM
Cylinder bore is diameter, divide by 2 for radius then square, and multiply by Pi. This gets you the cylinder cross sectional area. Multiply this by the stroke legnth of the piston and you will have the displacement volume of that cylinder. If the engine has multiple cylinders of the same dimensions, multiply the volume by the number of cylinders.
If you want displacement in CC all measurements should be in CM.
Register to Reply 3 comments
Ace Boeringa (1); durtieduck (1); Joshi (1)
