Previous in Forum: Zero Sequence Current   Next in Forum: Transformer Outgoing Cable Getting Heated Up
How to Check Diesel Generators Sensors
11/25/2012 2:03 AM
i want to know how to check the diesel generator temperature and pressure sensors ..please any body tell me,,,,,,,,,,,,,,
Good Answers: 34
Re: How to check diesel generators sensors???????
11/25/2012 2:29 AM
If you had first Googled, you would have known the answer first hand. Friend, do learn how to Google. Your answers are in link below:
How to check/test the temperature and pressure sensors.
Re: How to Check Diesel Generators Sensors
11/25/2012 6:10 PM
Testing gen sensors is part of commisioning if you have not done this before I would
recommend profesional help - however temp sensor - you remove the sensor and
place it in an oil bath with a thermometer - you then gently heat the oil , the sensor is
connected to a multimeter at the correct temp ( stamped on the sender) the sensor contacts will either open or close give or take a degree or two verify with thermometer ( this is a critical shutdown and if it fails you could loose the engine)
As for preasure use a preasure pump with a acurate PSI gauge connect the sender and slowly pump up to sender rated preasure
the rated preasure of the sender should be stamped on it -and it should change state when the rated preasure is reached +or -
the multimeter will either close or open at that point - verify with pump Gauge should
be within a 2% OR SO . Again this is a critical function if it fails you could loose the engine ( Low oil Presure)
Regards
Rob
12/10/2012 1:33 AM
Thank u rob
12/01/2012 11:15 AM
Please refer to www.nandipower.net . May be helpful for you.
Register to Reply 4 comments
dineshsjce1 (1); Joshi (1); kumaranaveen (1); robM (1)
