Previous in Forum: Fans in Series   Next in Forum: Wireless Fuel Station Management System
How to Work Out Force Pull Required
11/25/2012 8:33 AM
Folks I have a lever that I can attach a digital scale to that gives me the amount of pull required to operate it in Kg or pounds. How do I then use this reading to select a solenoid to pull this lever? as the solenoids I have seem show either N or gf is there a simple way to convert the reading I get on the scales into the spec offered on the pull solenoid? thanks G
Re: how to work out force pull required
11/25/2012 8:35 AM
Yes. Use any of the hundreds of conversion sites you can find on the web.
Or, ask the sales rep for help.
Good Answers: 34
11/25/2012 8:49 AM
Use the link below, you may find some clue.
Determining pulling capacity of solenoids
11/25/2012 10:28 AM
Well I do understand part of your confusion. Your force (weight) scale is technically mislabeled. Pounds is a unit of force but kilograms (Kg) is actually a unit of mass. The proper International System (SI) unit for force is the Newton (N).
There is a very simple way to convert these measurements. It is so simple though that not knowing how to do it means that you will probably not understand what it means.
Re: How to Work Out Force Pull Required
11/25/2012 6:13 PM
gf(req'd) = kgf(given) x 1000. No conversion needed; just note prefix.
11/25/2012 10:44 PM
1 Kgf = 9.8 N approximately. You consider the same and go ahead in selection
Best Regards, Shivaram
Good Answers: 59
11/25/2012 11:26 PM
Why do you bother us with schoolwork? Switching from english to metric is a trivial exercise.
11/25/2012 11:35 PM
Obviously some people cannot do rudimentary schoolwork, even with search engines.
Register to Reply 7 comments
Joshi (1); leveles (1); lyn (1); redfred (2); shivaganti (1); Tornado (1)
