Previous in Forum: 1998 Chevy Cavalier Brake/Turn Signal Lights Do Not Work   Next in Forum: 2001 Chevy Cavalier
17 comments
2001 C240
11/25/2012 7:13 PM
I have a 2001 C240 6 spd. I'm that car savy so i need alot of help. My wife was driving my car and she said when she came to a quick stop wiht the car in 1st and clutch pushed in the car just cut off. It wouldnt restart for about 30-35 min after. I drove it around the parking lot and then on the road when i came to a stop light i put in in nuetral and same thing happened. I checked coolant level oil level and all checked out good. what could the problem be??
Pathfinder Tags: c240 engine problems Mercedes
Good Answers: 53
Re: not too sure whats wrong
11/25/2012 7:19 PM
The problem could be an intermittently open electrical circuit.
Ace
11/25/2012 7:21 PM
ok do know a rough estimate of what that might cost to repair?
Good Answers: 53
11/25/2012 7:31 PM
If the problem is obvious and your friend/neighbor just re-seats or tightens a connector it could cost you a beer. If you take it to an import auto shop and they replace components based on what they think it might be until the problem seems to go away it could cost thousands.
11/25/2012 7:33 PM
ok thank you ACE
11/25/2012 7:44 PM
also I checked the coolant level in the small tank and it was completely full all the way to the cap. Could that play a factor I know its not supposed to be that high?
Good Answers: 53
11/25/2012 8:31 PM
Probably not by itself, but that is a symptom of a blown head gasket.
Good Answers: 34
11/25/2012 8:57 PM
Blown head gasket? But the coolant tank level has not gone down. OP confirms, the level of the coolant is up to the cap. That will suggest, the coolant is not circulating. Am I wrong, or misunderstood OP?
Good Answers: 53
11/26/2012 12:20 AM
Joshi,
It depends how the head gasket leaks, if high pressure combustion gas escapes into the cooling system it can force coolant through the radiator cap topping off the coolant resorvoir. This is certainy not the only scenario but I have seen it happen.
11/26/2012 12:25 AM
like I said before im not too car savy but a b lown head gasket wouldnt that cause the car to stall so to say every time i got to idle speed. it only cuts out after 5-10 min of driving and i come down to speed none of my gauges are showing high temps either or anything like that. I have a check engine light and the ESP thing comes on all the time now.
Good Answers: 34
11/26/2012 12:35 AM
Thank you, Ace Boeringa, what you say is valid.
Re: 2001 C240
11/25/2012 9:19 PM
Take it to a mechanic!
No offence to you, or our members for trying to help, but braking should not kill an engine.
If the engine dies when you really, really need to stop you may have a problem.
Not only with stopping, but steering, if you can't stop.
Re: 2001 C240
11/25/2012 10:08 PM
thank you
Re: 2001 C240
11/25/2012 10:12 PM
I think we may have an automotive oxymoron here. This is a Mercedes Benz with a frugal owner looking for repair cost estimates from people incapable of putting their hands on the vehicle. I know that this is an eleven year old vehicle but a mechanic (shade tree, local chain, or dealership) should look at this vehicle. It is good that the owner can replicate the problem but knowledgeable hands, eyes, and ears should view this machine.
Good Answers: 53
Re: 2001 C240
11/26/2012 12:50 AM
Houston we have a problem... You have not asked what you should do about it, but it is becoming evident that advice is what you may be after. I don't usually give unsolicited advice but I will offer you a clue, your car has electronic on board diagnostics that saves problems in memory.
If you're not asking the right questions it is unlikely that you are getting the right answers.
Re: 2001 C240
11/26/2012 12:57 AM
thank you ACE..
Im looking for both possible problems and advice. so far ive gotten three different problems that i will be looking into. But I also wuld like to know if this is the kind of car i should keep or fix the problem and get rid of it. Im the 3rd owner and really first problem I've had it only has 50k miles and i really like the car but I dont really have a lot of money to throw into it either
Re: 2001 C240
11/26/2012 3:05 AM
it could be dirt laying in the fuel tank. stopping can pull the dirt [rust], or water particals from the bottom of the tank to the fuel pump pick-up screen, staving the engine for fuel. . the particles then settle to the bottom of the tank after a certain amout of time, allowing the car to re-start. check the fuel filter too.
Good Answers: 123
Re: 2001 C240
11/26/2012 1:40 PM
IF you want to find out what IS wrong, you will need to get your hands a little dirty.
Do you have access to a test light, or voltmeter? If so, connect it to the low voltage side of the ignition system. Now make the car repeat the problem, and observe the test light-meter. If the tester shows no power, there is an open in the ignition circuit. If there is still power, you need to test the power to the injectors, or monitor the fuel pressure. Are you prepared to do this? If not, try to understand how the test procedure works, and then ask your favorite repair facility how they would diagnose it?
Bob
Register to Reply 17 comments
Ace Boeringa (5); bob c (1); durtieduck (1); Joshi (2); lyn (1); mhouston23 (6); redfred (1)
