Previous in Forum: Flange Material   Next in Forum: Spiral Plate Heat Exchangers
PWHT
11/26/2012 7:34 AM
Why code B31.3 told us to perform always PWHT for thickness above 19 MM and is not required for below 19mm unless there is material or client specification reqirement???
Re: PWHT
11/26/2012 7:44 AM
Presumably because B31.3 requires PWHT for 19mm and above regardless of whether there is a client requirement.
Good Answers: 34
Re: PWHT
11/26/2012 10:32 AM
If you know, Why post weld heat treatment is required, then you will know your answer.
Register to Reply 2 comments
