Previous in Forum: What are manifolds used for?   Next in Forum: Steel W85 - where can I find it?
Concrete coating of pipelines
05/22/2007 4:00 PM
Dear coleagues,
As a corrosion engineer in corrosion mitigations and protection, I am faced to applying for the position as described below. Can any one tell what I should know about concrete coating of pipelines as stated below? Can I go for this job? Please can anyone help me out of what I should know or do in other to catch the job?
You will serve as an expatriate consultant on Engineering/ Building Ground Maintenaces Services for supervising contractors with the mandate to carry out linepipe coating for the project linepipe/ concrete coating for the diameter (24 inches or greater) line pipe and also pipeline/ concrete coating for long (25km or greater) pipeline, who also have the capability of pipeline/ concrete coating of 40 inches linepipe and the capacity to coat up to 100km of such linepipe within six(6) months.
Scope of Work:
1, To execute a job for pipeline/ concrete coating of 400 inches diameter linepipe of up to approximately 100km lenght.
2, To apply a three layer polythethylene pipeline/ concrete coating system to the exterior of the linepipe.
3, To optionally coat approximately 60km of 40 inches diameter linepipe for the project.
Re: Concrete coating of pipelines
05/23/2007 3:09 AM
what you describe as a 'position' that you are thinking of applying for is not a job for an individual but an invitation to tender. Concrete lining and external coating of linepipe is a specialised job that needs specialised equipment and materials and a factory to carry out the work.
05/23/2007 4:48 AM
Thank you very much for your advice.
Good Answers: 243
05/23/2007 10:39 AM
Actually it is a position- for the consulting engineer overseeing the work of the project and the contractors.
Ability to manage logisitics, audit paperwork, track completion, far flung supply chains in different languages, quality assurance of provided materials , and documenting work procedures and maintaining non bribeable surveillance of workmethods (and the work itself) are some relatively less technical areas for you to consider. also, your ability to deal with off road living condidtions for extended periods.
Biggest issue is whether or not they actually apply the doggone stuff when you are not there. So knowing how to purchase satellite imagery might be an important competencey to have.
milo 'You'll be the engineer of record, and you'll be in their country subject to their legal systems'
05/23/2007 3:14 AM
AS PER YOUR MAIL,
You want a coating expert consultacy address please go and search google lot of experts address is available in webistes try to find out ,it is not possible to do without expertise advice.
Binoi.S
05/23/2007 4:49 AM
You were very helpful so I am saying thank you
alf robertson (1); Anonymous Poster (3); Milo (1)
