Previous in Forum: Boiler Woes   Next in Forum: Bumming Around the World
Clarification: Home Brew Windmill System
11/28/2012 9:42 AM
My understanding of home brew windmill system as it referrs to the term cut in, is that cut in is what it takes to fill the coils and wires and bridge rectifiers and the resistance included to that point after that you are charging the batteries. Is that correct?
Re: Clarification
11/28/2012 10:28 AM
Re: Clarification
11/28/2012 11:33 AM
thank you cut in is when the generator or alt voltage is higher than the battery bank voltage. appreciate your help
Re: Clarification
11/28/2012 12:10 PM
thank you cut in is when gens voltage is higher then battery bank starts charging the batteries
Re: Clarification
11/28/2012 10:36 AM
There isn't such a thing as "filling the coils...resistance." Instead, when the turbine spins fast enough to generate usable voltage (> existing), a switch "cuts it in" to feed the system.
Good Answers: 26
Re: Clarification: Home Brew Windmill System
11/29/2012 12:38 AM
The term "Cut In" is used to reference the wind velocity required for the wind turbine to begin generating any useable electricity.
Barchetta (1); johnnyb5 (2); Randall (1); Tornado (1)
