Previous in Forum: Magazines for Stacker Reclaimer   Next in Forum: What is Diversity Factor?
CT Shorting for Spare Cores Link
11/28/2012 12:12 PM
Please answer this question,
I have HT (6.6 ) KV motor feeder.
It has dual core CT,.
1 st core as protection CT ( U1-U2 for R phase, V1-V2 for Y phase , W1-W2 for B phase), it is connected to relay and is of 5P10.
second core is metering CT ( again same as above that ia 3 phase) with secondary of 1 Amps & cl 1 accuracy.
Here is the problem,
I want to connect only single phase ammeter ( at motor control station in field) to this metering CT ( suppose I connect to Y phase).
If I short circuit the R & B phase in switchgear , then can there be any problem....
and what kind of???
thanks
Pathfinder Tags: ct short Spare cores
Good Answers: 131
Re: CT Shorting for Spare Cores Link
11/28/2012 1:06 PM
You should be able to connect a single-phase ammeter to only one of the phases of the 2nd core of the CT. The other 2 phases should be shorted and grounded. However, you will know only what the current is in the Y phase, and not the other two phases. That's probably not a big deal with a motor.
12/01/2012 12:23 PM
Hi,
You may also consider installing a selector switch with the ammeter in order to retain flexibility to view current in any phase.
All the best.
Register to Reply 2 comments
