Previous in Forum: Gauss-Seidel Method in Load Flow   Next in Forum: Current Transformer Secondary Grounded
Relay Setting
11/30/2012 11:15 AM
What is the approximate range setting for any kind of relay (UV,OV,OC,EARTH FAULT,UNDER IMPEDANCE etc.)in transformer/generator/motor.
Please name it with relay type & name....
Re: relay setting
11/30/2012 11:46 AM
You'll need one of these.
Photograph of a quartz crystal ball commonly used for divination or scryingThe Crystal Ball by John William Waterhouse: scrying in crystal
A crystal ball is a crystal or glass ball believed by some people to aid in the performance of clairvoyance.
And this. What are the rules and responsibilities of a CR4 member? Item #14.
Re: Relay Setting
11/30/2012 2:03 PM
I think what Lyn is trying to say is:
There are a metric ton of different relays. Then, within those categories, there are a metric ton of different options that you can choose from. If you'd like to learn more, GlobalSpec has some nifty learning materials on figuring out what kind you'd like / need for a process, and you can even sort by a plethora of ranges.
Here's a link to help you get started:
http://www.globalspec.com/productfinder/findproducts?query=relays
If you need a specific relay per an application, we might be able to help you out a little more, but til then, you might have to do a little digging around or try to narrow your question a little bit more
The first law of thermodynamics is you do NOT talk about thermodynamics.
Re: Relay Setting
11/30/2012 2:13 PM
Mizuti, I'm just curious...
Did you use a Ouija Board, crystal ball, or magic 8-Ball to divine that metric units should be used in your answer?
Re: Relay Setting
11/30/2012 2:17 PM
Thanks for your interest Doorman. I went with the magic 8-ball this time around.
Re: Relay Setting
11/30/2012 2:20 PM
He used logic. A metric ton is larger than a ton ton.
That translates to even more relays out there.
Geez, now we're even speaking for each other.
Re: Relay Setting
12/01/2012 10:02 AM
The range is approximately anything, for any kind of relay...you name it!
Register to Reply 6 comments
Doorman (1); lyn (2); Mizuti (2); Tom_Consulting (1)
