Previous in Forum: Relay Coordination Project   Next in Forum: Wattages of Various Luminaires
10 comments
Energy Consumed by a Tube Light Ballast
12/02/2012 12:12 AM
What is the wattage consumed by a ballast used for a fluorescent tube light ? There are electronic ballasts now-a-days. I want to know the wattage of these and the older version
Engineering Fields - Control Engineering - Control Engineering Technical Fields - Education - Industrial Training Engineering Fields - Manufacturing Engineering - Manufacturing Training Engineering Fields - Electrical Engineering - Electrical engineering Training Engineering Fields - Instrumentation Engineering - Instrumentation Engineering United States - Member - New Member Engineering Fields - Energy Engineering - Become part of the larger group, change your world.
Re: Energy consumed by a tube light ballast
12/02/2012 12:33 AM
Some host 25% savings between magnetic and electronic ballast. By in the real world is about 5% to 15% savings to go from magnetic to electronic ballast.
AB PLC Training onsite, On-Line, training software and more. BIN95.com
12/03/2012 2:52 AM
If you want to save electic change the ballast over to LED transformer and put in a LED light tube, your watts will drop from 35w to 6w. you can change 1000w mercury to 50w LED.
12/02/2012 11:11 AM
basic ohms law applies to both...do your own math, stop being so lazy
12/02/2012 4:05 PM
You can figure that an average decent quality magnetic type ballast uses around 10% of the bulbs rated power and a electronic one is around 5% of the bulbs rated power.
To be honest when you factor in the cost differences Vs the little bit of energy savings between the two its rarely cost effective to replace a older magnetic ballast with and electronic one just over perceived energy savings alone.
However if the old magnetic ballast needs replacing then yes going with a new electronic one instead is worth it.
Re: Energy Consumed by a Tube Light Ballast
12/02/2012 11:14 PM
The apparently incompatible figures above may well be correct: the efficiency of the fluorescent tube itself can be higher when supplied via a HF electronic ballast.
BTW, there are three additional reason you might wish to replace a magnetic ballast with a HF electronic one: extend both ballast life and tube life (significant if routine access is costly and you are having works performed anyway), and the higher frequency improves the quality of the light - more noticeable if you are on 50Hz mains than 60Hz, but essential in machine shops in either case.
12/03/2012 1:00 AM
Another advantage of electronic ballast is that the fluorescent tube can work with lesser voltage (say 80% of rated voltage) without flicker.
12/03/2012 9:17 AM
THIS gives some insight with figures to "Electronic Ballast" (perhaps i spotted a wrong 1 - i can see a coil on schematic - there should be something called ACTIVE INDUCTOR instead - would be more "Electronic")
ci139
Good Answers: 73
12/03/2012 10:49 AM
Well, the lamps will still have coils. That is what supports the active emitter material where electrons jump from a solid material to a gas and back.
Some of these electronic ballasts are pretty cool. If you ever studied oscillator circuits and took note of the active Q value of the circuit, then you can see something very clever used in starting and running these lamps. Before the lamp lights, the Q is very low and the frequency generally climbs. But as the load kicks in, the Q goes up and the output voltage drops. It is all very analog but it works seamlessly.
12/03/2012 12:54 PM
In theory, none, but as others have said there is some loss. Please explain what you are trying to do. Your post is not clear.
12/03/2012 9:02 PM
As I was given to understand, ballast takes about 15 watts for the old type and about 5 watts for the electroniuc one. During the calculations for wattage of tube lights, usually 40 watts are taken for a 4 feet tube light and hence my question.
There have been suggestions from the members as to how I should go to basics etc. All said and done, there are quite a few things unexplained and not taken care of, and hence my question.
Anyway, as I could see the consumtion is about 4 to 5 watts only. And thanks
Register to Reply 10 comments
Anonymous Poster (1); BIN95 (1); ci139 (1); debata07 (1); Fredski (1); Gadepalli Subrahmanyam (1); Larry Burns (1); NotUrOrdinaryJoe (1); StandardsGuy (1); tcmtech (1)
