Previous in Forum: The Tin Of Mystery   Next in Forum: OK, So What was the Mars-Shattering News?
16 comments
Glacier Bay Faucet Failed in Less Than 2 Years
12/03/2012 1:48 PM
About 2 years ago I replaced the faucet and sink cabinet in the basement bathroom. It was a cheap cabinet that was looking shabby, and the faucet had been dripping for a long time. I replaced them both with nice looking Glacier Bay units for Home Depot. The price was good, I thought. The cabinet had a solid wood door, but the rest was particle board with veneer, as was the previous. Considering how long the old one lasted, and my age, these, I expected, would last the rest of my life. Not so.
I noticed a small puddle on the floor after my son had showered, and thought it came from there. A few days later there was a larger puddle in front of the sink. It was not the trap; I had put in a plastic one when I made the installation. It was not the flexible pipes that replaced the solid ones. It was not leaking at all when the faucets were off, only when the water was running. It was not leaking from the sink. It was leaking from the faucet from the hole where the push rod goes to stop the sink!
I had been given a gift card to Lowes, so I got the replacement there. I avoided American Standard after Kramarats post on their toilets. My experience with Delta has not been great, so I got a Moen. It is US made, and has a limited lifetime warranty. I just got it put in, and there are no leaks, with or without the water running. I left the "old" drain pipes there which appeared to be the same quality as the ones with the new faucet.
The cabinet has some swelling, but I chose not to change it just yet. I may want to put a real wood "kick" board at the bottom. One reason I chose the Moen, was because the push rod is completely separate from the water flow. I had to drill another hole in the sink behind the middle hole for the push rod. For some reason, the Moen push rod was bent at an angle about halfway down. That didn't work with the Glacier Bay cabinet, so I chose to straighten it rather than use the old push rod with a different design.
-S
P.S. I have no financial interest in Moen
Re: Glacier Bay Faucet Failed in Less Than 2 Years
12/03/2012 3:38 PM
I got a $500 Moen faucet for my kitchen at Habitat For Humanity, for $100. Don't ask me who would pay $500 to turn water on and off..............it's not me.
Anyway, I went to install it about a month ago and realized that one of the plastic quick connects was broken. I couldn't find the part anywhere. Finally, someone told me to just call Moen and they would replace the part. I did, and they sent the part right out.
I'd prefer to be able to run down to the hardware store and just buy what I need, but I can't really complain. The Moen lifetime guarantee is for real.
PS- Still no toilet clogs since the rebuild.
12/03/2012 4:23 PM
Yikes, I only paid $72 plus tax for the new one. The Glacier Bay was on sale for ~$25 (made in China).
12/03/2012 5:24 PM
Yeah, I'm getting close to wrapping up the kitchen remodel.
My wife is winning any arguments, so I do what I can. She's actually right, now that I look at it.
I would have been fine with Formica..............she wanted black granite. I'm glad she won. It's pretty sweet.
I scored on the faucet. It's kind of a brushed nickle gooseneck design. Good thing too. I don't think I could bring myself to spend that kind of money on a faucet.
Good Answers: 114
12/03/2012 5:02 PM
Glacier Bay is rubbish, you can tell that just by looking at both before you buy. There is a reason they are so cheap.
12/03/2012 8:27 PM
The outside of them has a good look (better that the old one I had). You cannot look at the bottom, because they are mounted or in a box that is sealed. Now that I have the Glacier Bay faucet removed from the cabinet, I see 4 screws coming down from the top. There appears to be gasket around the hole for the push rod. I will have to remove the handles and see if I can get to the screws. - please wait
I have no metric Allen set, but got them off with an English one. After removing the nuts below the handles and the aerator, a chrome-plated plastic piece came off below the spout. Now 2 screws holding the PVC? water tube, and presto, the chrome-plated metal piece is removed from the "works". - please wait
Now the 4 screws are removed from the PVC part to the metal part, but I can't get it off. The spout tube swivels in the lower part. I find that strange, because this was a fixed faucet. Hold on, two more Allen screws, one on each side - One side is loose, but crud buildup is holding the other - please wait
After hammer & vise it is off. There was no gasket, it was the PVC showing through. There is a red stain around where the push rod rubs the PVC, but I can't find a hole there. Each threaded metal pipe is bonded to a PVC tube which goes into the central PVC piece with 2 oval O rings each. The source of the leak is a mystery, but there are plenty of opportunities in a construction of this kind.
12/04/2012 1:14 AM
Take it back to Home Depot or whatever place you got it they will give you a new one.That's how it works buy crap return it and put in another one dumb but it works.
Even if you don't have a slip, if you used a card it's on record ,if not they will still give you another one just whine a little .
Regardless they all are crap that's the new world planned obsolescence ,by crap return it nice system.If they had one that really worked that wouldn't be good for business.
The $500 ones fail too in 3 years not 2 but by then you forgot where you bought it so your better off with the cheap one!
Lighten up
12/04/2012 10:40 AM
That's crazy. I wouldn't put another one in if they paid ME. Why would I take a chance of not only ruining the cabinet, but the floor and the wall behind? It's one thing for them to drip in the sink, and another to drip like crazy under the sink. I don't know what the warranty is, but it's probably not over 90 days. I probably didn't use a card, and may not have even registered the warranty. Now I have created a spreadsheet to keep track of the warranties that I have registered for. The reason for this thread is to put Glacier Bay out of business. The Moen construction is all solid metal (no PVC, no O rings).
Good Answers: 92
12/03/2012 10:29 PM
Moen makes faucets etc. in all sorts of price ranges and they each have their own quirks but the warranty is for real.
Our house is over 25 years old with several original Moen faucets & shower controls. Every few years one starts sticking- I have to pull it apart, take the cartridge to the local Home Hardware & they give me a new one for free.
Now if only they could stop the aerators from liming up......
Good Answers: 32
12/04/2012 10:43 AM
I went with all Moen when I built my retirement house. I found out through the contractor and plumber that not all Moen's are created equal. The quality of the Moen sold through Lowes and Home depot is not the same as sold through a good quality plumbing supply house like Ferguson where I got my fixtures. Am very happy so far with all their products but only time will tell.
You might try taking off and dropping the aerator overnight once a month into a glass of CLR or even just plain vinegar to keep the aerator clean.
Spinco
12/04/2012 7:49 AM
Glacier Bay is contractor grade Chinese Garbage.... Definately not for houses one intends to actually live in...
12/04/2012 8:43 AM
If you don't care what it looks like, get a faucet for a laundry/utility sink. They don't look pretty, but they are simple, cheap, and for some reason, reliable.
12/04/2012 9:41 AM
Just two words.. Price Pfister
12/04/2012 10:05 AM
Does anyone have this problem I have with a signle handle kitchen faucet:
I constatntly need to check that my wife and children turn this valve off all the way (forward center). They constantly leave it off to the side which leaves it slightly on.
12/04/2012 10:56 AM
I have a Delta single handle kitchen faucet. I replaced the neoprene parts to stop the drips a while back. Since then the handle must be pushed to the left and upward a little to stop the drips. Try to get your wife to do that! For these faucets you can replace more of the innards for more money, but I don't know how well that works. I also have a Delta single handle tub faucet that must be centered and pulled down to stop the drips.
Good Answers: 123
12/04/2012 11:02 AM
I don't have that problem with mine. The kids don't fill the ice trays, and are too good to drink tap water, so they don't use the kitchen sink.
Bob
12/04/2012 11:23 AM
Lucky You!
Note, I also have to close doors, cabinet doors, turn off lights, etc. that they leave open or on!
It must be that I am an Engineer or anal about this stuff.
Register to Reply 16 comments
bob c (1); Bongo Man (1); corbinstein (1); JNB (1); kramarat (3); Mechanicalmark (2); passingtongreen (1); Spinco (1); StandardsGuy (4); traditional (1)
