Previous in Forum: Question About Drying Theory   Next in Forum: TAPER Lock
What's the Difference Between Trapezoidal Tooth and Circular Tooth Timing Belt?
12/04/2012 3:37 AM
What's the different between trapezoidal tooth and circular tooth timing belt?
Re: What's the different between trapezoidal tooth and circular tooth timing belt?
12/04/2012 3:40 AM
One of them has trapezoidal teeth. The other has circular teeth.
12/04/2012 4:03 AM
I think you'll find the teeth are semi-circular in cross section.
The KrisDel circular teeth used to roll off all over the floor so we moved to semicircular, they stick on much better.
12/04/2012 4:04 AM
Thanks.What I mean is different about perfomance,such as accuracy,noise,bearing capacity.
12/04/2012 9:14 AM
Re: What's the Difference Between Trapezoidal Tooth and Circular Tooth Timing Belt?
12/04/2012 7:55 PM
Thank you very much!
Abstract:
The trapezoidal shape timing belt was superseded by a curvilinear tooth profile which exhibited some desirable and superior qualities. Advantages of this type of drive are as follows:
Proportionally deeper tooth; hence tooth jumping or loss of relative position is less probable.
Lighter construction, with correspondingly smaller centrifugal loss.
Smaller unit pressure on the tooth since area of contact is larger.
12/04/2012 8:02 PM
Thanks for the recap.
Just so you'll know, all I did was copy and paste "Difference Between Trapezoidal Tooth and Circular Tooth Timing Belt" into a search engine. That's just the title of your thread.
Simple.
Glad to help.
Now, you're obligated to stick around and help the next guy out.
12/06/2012 6:56 PM
about 10 bucks
Register to Reply 7 comments
Anonymous Poster (1); Finley (2); Fredski (1); lyn (2); user-deleted-1105 (1)
