Previous in Forum: Cooling load calculation   Next in Forum: Sealing points for compression fittings
Selection of Bearing
05/23/2007 7:17 AM
How can I select bearing size on various load?
Kindly give its procedure.
Mostafiz
Good Answers: 40
Re: Selection of Bearing
05/23/2007 10:51 AM
knowing your engineering specifications, contact tour bearing manufacturer. They are the experts. It is not only size that is important but material.
try:
http://www.globalspec.com/FeaturedProducts/Detail/Dynaroll/Bearing_Selector_Tool/13231/0
05/24/2007 2:12 AM
Tell me what the Application is and I will tell you what bearing to use.
Most of the Bearing Service people are not experts, but salesman - at least here in Australia
Sig
United States - Member - Woohoo Engineering Fields - Mechanical Engineering - New Member
05/24/2007 12:21 PM
There are some good websites out there for selecting bearings and calculating the bearing life.
Here is one from SKF that has links to calculations and selection programs:
http://www.skf.com/portal/skf/home/library?contentId=448003&lang=en
Here is another from Timken that does a good job explaining the bearing life especially for taper bearings:
http://www.timken.com/products/bearings/fundamen/calculate.asp
FYI-The type of bearing (deep groove ball, cylindrical, taper, spherical, needle, etc.) determines one of the factors in the equation and will affect the bearing life.
You should be able to contact someone at a major bearing company that could help with the calculations and bearing selection. Make sure you know the loads, speeds, and environment (i.e. outside, inside, exposed to the elements, temperature range, etc.) as these all affect the selection process.
Good luck.
Self-motivational quote: "If they can make penicillin out of moldy bread, they can sure make something out of you." -- Muhammad Ali
Nate (1); sigibush (1); techno (1)
